nitrous - Mustang Evolution
Old 02-24-2013, 11:46 PM   #1
13 stang22's Avatar
nitrous
lookin for a bit of boost...if I get a system will I have to do any expensive prep? is it safe on the 6? and will I see a significant gain?
13 stang22 is offline   Reply With Quote
Old 02-25-2013, 12:27 AM   #2
Charlie_santos's Avatar
Soooo before i start helping out bro i need to know what u got in ur car so far? Intake? Tune? Gears? Tires?
Old 02-25-2013, 04:58 AM   #3
rebeltx's Avatar
There are a few people here in FL doing it. I think most of them are shooting 50 and 75 shots. Seems to me that there handling it well, mostly has to do with a good tune. I think I'm going to do a zex blackout kit myself.
CAI
tune
3.73 gears
Drive shaft ordered
Will add cat deletes and LCA with the order
Need to find someone that can go a good tune. Also, where did you tap for fuel and what line on the TB outputs control voltage?
What kit are you running?
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 02-25-2013, 08:01 AM   #4
13 stang22's Avatar
bama race tune. 3.73 gears. C & L intake. BBK throttle body. aluminum driveshaft. LCA. UCA
Old 02-25-2013, 08:33 AM   #5
Thats a pretty good mod list bro! U running stock 225 rear wheels? They will spin like crazy with gears and Nitrous cuz they new ZEX kits like i have go off the Throttle Positioning Sensor. Basically at WOT the NOS will begin to Spray.
I have 4.10 gears and my tires spun already because of them but with spray holy hell do they spin. At the track i barley hook before 3rd gear. And i have Nitto's 555's.
Your going to need a New tunes for ur car for NOS or you will melt a whole in ur engine.
I have two tunes. 93R with 50/75/100/125 shots
And my 93H with 50/75/100/125 shots.
I personally bought the Zex Wet system for the previous model V6 because they didn't make it yet for the 3.7L but now they do so i would personally recommend that kit!
Install is fairly easy. Mount the tank in the correct position in the trunk where the spare is, run the NOS tubing through either the cabin into the firewall like me or drill a whole in ur trunk and run it below the car. Then run it to the fuel tap line ZEX sends you, then to the control box and one line for fuel to the control box. Then the two hoses go into the V-Spray Connector with your jets. Then you simply splice ur TPS line with the line to the control box. Connect the positive and negative leads of the control box which puts it in learning mode. This is where u need to have ur intake off so you can manually open the throttle to full WOT to teach the control box when to engage. Thats it.
---------- Post added at 08:33 AM ---------- Previous post was at 08:32 AM ----------
CAI
tune
3.73 gears
Drive shaft ordered
I personally just went with Bamma Tunes. They work for now so i see no reason why it wouldn't work for you bro. Also idk the correct wire for the TPS but ill take a pic later today for you.
Old 02-25-2013, 08:41 AM   #6
13 stang22's Avatar
yeah. I have stock tires that come with the premium package whatever that is n they spin bad but the LCA controlled it a bit. I plan on getting new staggered wheels In which I'd probably go with nitto tires. and ok so tuning is the big thing I gotta worry about. and you recommend Zex? ill look into that! thanks for the extensive reply! helped alot!
Old 02-25-2013, 09:46 AM   #7
I wanna be thorough bro so u know everything before u jump the gun like i did bro.
If u dont have UPA then that LCA is useless honestly. And yes if u dont get a tune for the shots ur running u WILL BURN A WHOLE IN UR ENGINE haha that being said, just go with Bamma tunes bro
Old 02-25-2013, 09:58 AM   #8
13 stang22's Avatar
what is UPA again? I drew a blank...
Old 02-25-2013, 11:10 AM   #9
Upper control arm lol id get adjustable for both LCA and UCA
Old 02-25-2013, 11:39 AM   #10
13 stang22's Avatar
haha Ight bro. this sounds stupid but I've never dealt with nitrous before...is there like a switch or something to engage the nitrous?...lmao
Old 02-25-2013, 12:15 PM   #11
Hahaha na the ZEX system is dope. It engages at full WOT basically full throttle and there is a switch to turn off the system and on for daily driving lol u dont wanna be spraying just flooring it on the streets hahaha
Old 02-25-2013, 12:19 PM   #12
13 stang22's Avatar
would you be able to smoke a 5.0 with it?
Old 02-25-2013, 12:21 PM   #13
We do now lol mostly cuz of my 4.10 gears. But i can only beat like stock 5.0's with maybe just an intake a tune anything beyond that still beats me but not by much
Old 02-25-2013, 12:24 PM   #14
13 stang22's Avatar
well with all that I have I smoke 4.6s but I raced my friends 2013 5.0 with tune intake and 3.31 gears and I lost by almkst a car length. if I had this nitrous should I be able to beat him. [removed due to content]
Old 02-25-2013, 05:44 PM   #15
rebeltx's Avatar
I didn't know Bama had nitro tunes... Cool. How does your tune run when your not on the spray? I'm sure there are some adjustments made in the tune for the NO2 in the top end, how does the car act when you punch it with a nitro tune loaded but don't spray?
Old 02-25-2013, 05:48 PM   #16
It hiccups but continues normally, like it acts like its waiting for the spray but no spray lol its like waiting like whenever u wanna spray bro hahaha
Old 02-25-2013, 09:14 PM   #17
rebeltx's Avatar
You swap spark plugs as well?
Old 02-25-2013, 10:10 PM   #18
No one makes colder spark plugs so im just checking my plugs after every race and i change them every other bottle fill up
Old 02-25-2013, 11:16 PM   #19
curtin1991's Avatar
Send a message via ICQ to curtin1991
Let's see some pics I didn't even hear you where getting the kit lol.
Corey
curtin1991 is offline   Reply With Quote
Old 02-25-2013, 11:24 PM   #20
Hahaa i got it 3 weeks ago
Old 02-25-2013, 11:43 PM   #21
1slosix's Avatar
please don't just slap on some UCA's without torque box reinforcments....
carving corners like a boss
Old 02-25-2013, 11:46 PM   #22
Lol i got both LCA and UCA both adjustable
Old 02-25-2013, 11:47 PM   #23
1slosix's Avatar
good luck with that after a few good passes
Old 02-25-2013, 11:56 PM   #24
HPS adjusted it all for the track and then readjusts my car when i leave. They sponsored me because ive been getting all my parts installed for me. All they do is build drag cars so ima go with what they recommend not you, no offense or anything bro just rather take advise from a shop that builds and races drag cars for a living
Old 02-26-2013, 12:02 AM   #25
1slosix's Avatar
yeah i can tell you don't do your own work let me know how those tq boxes are holding up after a dozen more of those "12" second passes ok.
@op..i do reccommend reinforcing the tq boxes with any UCA addition....doesn't matter whether tubular or boxed design, spereical or sold bushing...always reinforce
Old 02-26-2013, 12:20 AM   #26
Hahaha ive done about 3 dozen passes hahaha so yea sure buddy lemme know when i should start to worry. No need to reinforce if u aint driving a big *** shelby.
---------- Post added at 12:20 AM ---------- Previous post was at 12:16 AM ----------
**** it ima make my mustang like the one from death race 3
Old 02-26-2013, 12:21 AM   #27
1slosix's Avatar
Old 02-26-2013, 12:22 AM   #28
Didnt work. All i see is the guy from heros looking like he's picking up a phone call
Old 02-26-2013, 12:23 AM   #29
1slosix's Avatar
try getting on a computer and not your phone
well i'm out...unless OP has any other questions
Old 02-26-2013, 12:28 AM   #30
Eh i dont wanna be in front of a computer all night AINT NOBODY GOT TIME FOR DAT!
Old 02-26-2013, 12:31 AM   #31
1slosix's Avatar
except all you post from is your iphone
Old 02-26-2013, 12:40 AM   #32
Like i said i don't wanna be in front of the computer this way i can watch death race and reply its a win win buddy
Old 02-26-2013, 06:39 AM   #33
13 stang22's Avatar
I think I got my questions answered. thanks alot Charlie santos and slo! this was a funny thread btw! lmao
Old 02-26-2013, 07:45 AM   #34
JimC's Avatar
Don't rely upon the Zex NMU to be accurate reading WOT. Get a window switch. I had it on my 2006 and had the system armed as I was lining up. Did pre-stage, brought the RPM up to 1,500 to stage and the NMU read me as being at WOT and fired off.
Got the window switch installed after that so that the signal was blocked from the NMU until I was over 2,400 rpm. You don't want to be spraying too low in the rpm because you will find another "window" opening in the block.
JimC is offline   Reply With Quote
Old 02-26-2013, 02:26 PM   #35
Idk about your system back then bro but i can see my rpm jump when the spray engages and ican tell you that the new zex system does not engage until my foot is down on the pedal bro.
nitrous
06:11 PM
