SR Short Shifter headache - Mustang Evolution
Old 03-06-2013, 09:46 PM   #1
sprdave's Avatar
Just a heads up, to any member who has installed one of these.I'm driving home the other night and i can't shift into 4th gear fully.I skip 4th so I won't damage anything.
When I get home I pop off the console and boot and see that both pieces of the
aluminum shifter plates are moving freely.
Today I got up early and jacked up the car,so i could remove the two nuts from the bottom.Then removed the four bolts and took out the SR shifter.The four bottom bolts on the shifter were totally loose.I assume they were not tightened from the factory.
There was no info about this in the install instructions.
What a headache to fix this.Sorry for the long post.Just maybe I can save someone else trouble.I thought it might be my transmission.
sprdave is offline   Reply With Quote
Old 03-10-2013, 12:47 PM   #2
Ntbruncie's Avatar
Damn that sucks. Was it grinding going in to fourth?
Ntbruncie is offline   Reply With Quote
Old 03-10-2013, 02:57 PM   #3
sprdave's Avatar
Well, last week one day on my way to work it didn,t feel like it was all the way into 4th gear.Luckily it didn't force anything and skipped 4th and used 5th gear instead.
I just wanted to let anyone else who installed one of these,that if shifting troubles
come out of no where,it could be this.
After I tightened all the bolts super tight,it is back to shifting better than ever.
Old 03-10-2013, 03:44 PM   #4
Ntbruncie's Avatar
That's good that you got it working correctly
08:21 AM
