vibration or whining - Mustang Evolution
Old 03-08-2013, 08:23 AM   #1
clamphier's Avatar
I just got gears and a drive shaft. If the pinion angle on the driveshaft isn't perfect will it vibrate or make a weird noise, or is it going to be the gears?
clamphier is offline   Reply With Quote
Old 03-08-2013, 08:39 AM   #2
Charlie_santos's Avatar
If it whines on deceleration its ur gears, it needs to be reshimmed
Old 03-08-2013, 08:41 AM   #3
clamphier's Avatar
Its cruising at like 70 it stops when I decel
Old 03-08-2013, 09:09 AM   #4
clamphier's Avatar
It's really confusing, I guess it might still be the gears breaking in Idk makes me nervous though
Old 03-08-2013, 09:10 AM   #5
Your car shouldnt whine at all!! If its whining go back before ur gears grind and slowly mess up. Please dont just leave it like that bro!
Old 03-08-2013, 09:19 AM   #6
clamphier's Avatar
I don't think it's gear whining though I don't want to leave it. Its not loud it's more like a hum that's why I think its the driveshaft. I've checking it twice the backlash is good and the pattern is nearly perfect on the gears. That's why I'm confused
Old 03-08-2013, 09:33 AM   #7
If its ur drive shaft then thats an even bigger problem! If its vibrating then u do know it will blow up and high speeds! The point of a new drive shaft is to shed weight and be able to rotate even faster but if its slightly off even a tiny bit, when at high speeds it will end up vibrating more and more to the point of it exploding. Be very careful and try and pin point the issue.
Old 03-08-2013, 09:44 AM   #8
clamphier's Avatar
I know I'm in the shop today I think it was after I took put the driveshaft to put in the gears, hopefully I can get it figured out!
Old 03-08-2013, 10:17 AM   #9
Rosco's Avatar
If its whining only during acceleration that sounds like a pinion bearing. It could be the preload wasn't set correctly, the bearing could be damaged... I would take it back and get it fixed.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 03-08-2013, 10:29 AM   #10
clamphier's Avatar
Yea I'll check it out!
Old 03-08-2013, 05:05 PM   #11
clamphier's Avatar
I just got it checked out and everything is good its just getting magnified through the car because my body is really stiff so I'm just feeling all of that.
Old 03-08-2013, 05:15 PM   #12
MrMike's Avatar
Ok?!
MrMike is offline   Reply With Quote
Old 03-08-2013, 05:23 PM   #13
clamphier's Avatar
Idk Hennessey looked at it so I think I'm good
Old 03-08-2013, 05:26 PM   #14
MrMike's Avatar
Good. I hope everything works out. I plan on doing those mods one day soon!
Old 03-08-2013, 05:30 PM   #15
clamphier's Avatar
I just did the aluminum driveshaft and gears and it was so worth it!
Old 03-08-2013, 05:34 PM   #16
MrMike's Avatar
I might do gears and tuner sooner than later.
Old 03-08-2013, 05:38 PM   #17
clamphier's Avatar
What size gear are you thinking?
Old 03-08-2013, 05:44 PM   #18
MrMike's Avatar
3.73. Maybe 3.55 but leaning more towards 3.73.
Old 03-08-2013, 05:51 PM   #19
clamphier's Avatar
I was in the same spot I did 3.55s though because I'm more top end and i will probably be boosting soon and 3.73s don't give you much top end
Old 03-08-2013, 05:57 PM   #20
BlackedStang's Avatar
What driveshaft did you go with?
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 03-08-2013, 06:01 PM   #21
clamphier's Avatar
I did the drive shaft shop because it was stronger it was a little bit more expensive but I think it's worth it!
Old 03-08-2013, 06:13 PM   #22
Ah very nice, I have the same. Had it for a few weeks now very good quality shaft been 140+ numerous times no problems.
Old 03-08-2013, 06:23 PM   #23
clamphier's Avatar
I haven't got the right tune yet though. But I just did gears, driveshaft, and headers and x pipe this week so much better. What all do you have done to yours?
Old 03-08-2013, 06:25 PM   #24
I just have exhaust intake and tune, I want to get headers soon
Old 03-08-2013, 06:30 PM   #25
clamphier's Avatar
Headers make it sound so nice and gives you quite an up in power as well. Do you have axle backs or full exhaust?
Old 03-08-2013, 06:37 PM   #26
Yeah I want to get them but Im afraid it will be too loud. I just have axle backs
Old 03-08-2013, 06:50 PM   #27
clamphier's Avatar
Its really not that loud except for under full throttle. At cruising its the same as just having axle backs it doesn't get real loud till about 4k but it still sounds beautiful, at least I think so
Old 03-08-2013, 09:11 PM   #28
rebeltx's Avatar
Did you get a noticeable improvement when you put your drive shaft in? I have 3.73's installed, had them for about a month. My gears were silent till I lowered the car, now I can just bary hear them on decel but I have to almost try to hear them, if you didn't try to hear them you never would. I have a DSS aluminum 1 piece literally sitting in my room that I still need to put in, I got it because it had the CV joint over U joints front and back. Think I may put that in tomorrow, I'm glad others have this and are lilting it.
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 03-08-2013, 09:25 PM   #29
clamphier's Avatar
I think so! But I did gears, a driveshaft, and headers the same day so I couldn't tell what the difference was because I didn't do it individually. I threw it on the dyno today so I wanted to make sure I'd be good going above 140. But it cut a good fifteen pounds off and I think acceleration and shifting is a lot smoother with it. I also have upper and lower control arms a 2 inch drop and mine whine a little bit too, its the same as you I have to try to hear it. If you have it for sure put it on though it helps and it makes it where you don't have to adjust the pinion angle. It cuts down a lot on vibration too.
Old 03-10-2013, 05:04 AM   #30
rebeltx's Avatar
I will put it on as soon as I get the correct bolts from the drive shaft shop. The hex bolts I got barely thread into the adaptor plate and I found that I was not the only one with this issue. Apparently, quite a few slipped out the door with this issue. It's a simple fix but i will have to wait for the new bolts before installing this now.....
Old 03-10-2013, 09:03 AM   #31
clamphier's Avatar
Oh I understand well when you get it in let me knows how you like it! I love mine, I think I'm starting to get addicted to modding my car I have a problem lol
Old 03-10-2013, 02:03 PM   #32
rebeltx's Avatar
Yea... That will happen. I did CAI, tune, 3.73, lowered my car and put an in dash screen in within 3 months of buying my car... I still have the DS and some suspension work to do then I need an alignment cuz my camber angle is all screwed up
Old 03-10-2013, 02:11 PM   #33
clamphier's Avatar
Yea I voided my warranty at like 1500 miles, the only think that is stock now is my motor and that's going to change Wednesday. Did you get camber bolts or camber plates?
Old 03-10-2013, 03:45 PM   #34
rebeltx's Avatar
I need to get bolts. I forgot to order them with the springs...
Old 03-10-2013, 03:50 PM   #35
clamphier's Avatar
If your order them off late model restoration they will be there in two days. I ordered mine last night and they will be here Tuesday their shipping is so fast!
02:23 AM
