DSS Aluminum drive shaft install - Mustang Evolution
Old 03-10-2013, 05:06 AM   #1
rebeltx's Avatar
Has anyone installed there drive shaft themselves? I think I can do it on my own but I was wondering if there were things I should look out for before I started... Thanks
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 03-10-2013, 07:58 AM   #2
BlackedStang's Avatar
Yea me and my buddy installed mine a few weeks ago. All you really need is a jack, jack stands, ramps, torque wrench, breaker bar, some WD-40 and other basic hand tools. Was a pretty simple install, the stock DS was a bit difficult to get out, that took some time. But really it was easier then I thought it'd be. Only took maybe 2-3 hours.
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 03-10-2013, 01:49 PM   #3
rebeltx's Avatar
What did you use to lift the car? I was thinking about getting 2 more jack stands and putting the car up that way so I could still spin the drive shaft.
Old 03-10-2013, 03:15 PM   #4
sprdave's Avatar
Sounds like he drove the front of the car up on ramps and then jacked up the back
of it and put jack stands in the rear.That's what I did when I changed the LCAs.
sprdave is offline   Reply With Quote
Old 03-10-2013, 03:43 PM   #5
rebeltx's Avatar
That would be nice but I can't get the front of my car onto my ramps. I have SR springs so I sit low enough that the front bumper hits the ramp before the tire. I may need to remove the front bumper... I wonder how hard that is...
Old 03-10-2013, 03:44 PM   #6
You could jack up the side of the car enough to place the ramp on. One side at a time. But that's kind of risky.
Old 03-10-2013, 06:50 PM   #7
sprdave's Avatar
Well have you tried to drive up onto 2 or 3
same lengths of 2x4 or 2x6 pieces of wood first.
I do this to keep from hitting the chin spoiler.
You just have to put cement blocks in front
of your ramps so they wont slide on you.
Old 03-11-2013, 09:12 AM   #8
rebeltx's Avatar
I thought about the 2x6 trick but I would have to go buy and chop up all the wood for it. I don't want a 2x6 in my car and I don't really want to buy a saw just for this... I just bought my first house so every time I need something I just go buy all the tools so I have them later but I was really wanting to keep this simple... LOL
Old 03-11-2013, 09:52 AM   #9
the biggest issues is making SURE the driveshaft bolts are installed correctly. Not sure if locktite is recommended or not~ and not sure if its on there from the factory (may make removal a NIGHTMARE)
are the yokes already on it or do you have to swap those over as well?
Old 03-12-2013, 12:12 AM   #10
rebeltx's Avatar
The DSS drive shaft uses the factory yokes
Old 03-12-2013, 05:16 AM   #11
bucko's Avatar
Go here for removal and re-assembly info:
Ford Service Manuals - REMOVAL AND INSTALLATION - 3.7L.pdf
This is for a 2011, but should be simular for all years.
Old 03-12-2013, 06:42 AM   #12
David Young's Avatar
I used ramps for the front and jackstands for the rear. Very easy to install the driveshaft yourself. Be sure to use the right wrench i can't remember the size, maybe a 10mm 10 point wrench? so you don't round off the heads of the bolts.
David Young is offline   Reply With Quote
Old 03-12-2013, 11:12 PM   #13
rebeltx's Avatar
The stock shaft uses 12mm 12 spline bolts. I went and bought a deep well 12mm 12 spline to make life simple.
Old 03-14-2013, 03:19 PM   #14
rebeltx's Avatar
Im bout done playin with this stupid thing... I just cant beleave that Im only suposed to torque these bots to 75 lb/ft. Even with red lock tight on there I dont trust it.... Anyone done this install? what did you do?
Old 03-14-2013, 04:09 PM   #15
Huh? The loctite acts as a fastener so really you don't even need to torque them to 75. I only torqued mine to around 44.
Old 03-14-2013, 06:44 PM   #16
rebeltx's Avatar
nope, I got mine nice and snug
02:34 AM
