need helpful comments and suggestion - Mustang Evolution
Old 03-10-2013, 03:28 PM   #1
pony_'s Avatar
hi. i've got my stang last april. 12000k on it.
very first time, got some noise on wheels, so replace lower arm control both side.
now,
1. knocking noise on both rear wheels
2. bumping noise on front right wheel when i cross speed bump.
3. door knob is loose
4. seat belt sign light in not back on when it took off.
5. engine rpm drops down while idling
i sent her to service center for repair.
is it usual defects that on my 2012 mustang?
how is yours? it is very stressful to me...
pony_ is offline   Reply With Quote
Old 03-10-2013, 06:54 PM   #2
sprdave's Avatar
Mines been great.I assume yours is under warranty still.
You just need to keep on the dealership to fix these
problems.It sounds like you have some defective
bushings that need replacing.
sprdave is offline   Reply With Quote
Old 03-10-2013, 07:37 PM   #3
pony_'s Avatar
yes.. but i have no idea why the engine rpm drop down and up. it sounds like almost the engine stalled..
Old 03-10-2013, 07:50 PM   #4
pony_'s Avatar
thnks for the post
Old 03-10-2013, 08:17 PM   #5
deadsp0t's Avatar
Mods on your car, at all?
That's unimpressive
Old 03-10-2013, 09:32 PM   #6
sprdave's Avatar
Does your car have a tune?
If it does you need to get it adjusted
for the idle problem.
Old 03-10-2013, 10:17 PM   #7
pony_'s Avatar
never tuned.
Old 03-10-2013, 10:41 PM   #8
Sanguin's Avatar
A loose intake coupling can cause idle issues, basically unmetered air inlets. I have some clunking from the A-arms if I hit a speed bump too fast (makes the a-arm extend and pop). It never happens enough for me to even worry about it.
Besides small annoyances related to the wreck I had and the MT82 transmission's known issues, I can say the car has been really good. I've got one rattle coming from a gauge bezel I intend to fix, but it's a simple thing and only happens in cold weather.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 03-10-2013, 11:37 PM   #9
pony_'s Avatar
i heard that intake couple rings can make idle issues. i checked it is tightened.
i've got that noise(knocking sounds) last summer.
i've tried other mustang, i was not happened. makes me so stressful..
thank you for the post.
01:09 AM
