Rear Gear Pinion Bearing - Mustang Evolution
Old 03-11-2013, 12:27 PM   #1
Jayday20's Avatar
I saw on AM's website that you need the 8.8 rear gear pinion bearing when swapping gears. My car only has about 5,000 miles on it so will i still need to replace this? If so, I saw on a thread that you can get it from advance does anybody have the part number if you have purchased it from advance?
Thanks
Jayday20 is offline   Reply With Quote
Old 03-11-2013, 12:56 PM   #2
Charlie_santos's Avatar
Thanks
I honestly dont think u need it but i would advise it, get it autozone bro! Its just the 8.8 bearing from a f150
Old 03-11-2013, 02:11 PM   #3
clamphier's Avatar
I didn't replace mine you should be fine you can if you want but its not needed I used all the original everything just swapped out the gears and its perfect
clamphier is offline   Reply With Quote
Old 03-11-2013, 03:37 PM   #4
Jayday20's Avatar
Sweet I may just pick one up to be safe and will I need the install kit from am too? Sorry fir all the questions just wanna make sure I got everything.
Old 03-11-2013, 03:42 PM   #5
clamphier's Avatar
I bought the whole install kit through AM and I didn't use any of it besides the new bolt. All the rest of it was using all original shims and everything but I would get it just in case anything breaks plus you get royal purple and friction modifier. Especially if you mess up the crush sleeve that really sucks
Old 03-11-2013, 07:33 PM   #6
Jayday20's Avatar
Aight sounds good thanks for the help
Old 03-11-2013, 07:38 PM   #7
clamphier's Avatar
No problem let me know if you need anything else!
12:40 PM
