I have a 2013 mustang premium and my acceleration timer I feel is wrong. it's saying I'm 0-60 in 5.6 sec when I have cai bama hybrid tune ported throttle body and 3.73 gears. how accurate are these things? I have done a few pulls with a few respectable cars (at the track) and won.
It should be dead on. What altitude are you at? What is the road surface? Auto or manual? There are a lot of factors that go into a 0-60 time. My bone stock v6 runs low 5's also. (It's rated at 5.1 in ideal conditions at stock)
I'm in Texas. it's a good elevation. with everything I had on it it was running 4.9 - 4.8 sec. I put 3.73 gears on and it went up to 5.6. it feels faster. I also had a race tune when I was doing under 5 and I switched to hybrid. everyone says hybrid is better but idk if it is for me. I'm really confused. and I have an auto
Maybe the new tune didn't adjust your speedometer for 3.73 gears and its causing your track apps to be inaccurate. If you tell bama your speedometer seems off they can fix it.
Yes they are. Maybe they made a mistake though. Do you have a GPS or something else that can give you a semi-accurate speed reading? Maybe one of the police mounted displays on the side of the road somewhere.
Look at the file they emailed you and see if the 3.73's are listed on there.
My 13 Performance Packaged M/T is running 5.6-5.7 with my winter tires running Slightly uphill with spin in first and second on an 87 Tune.
Make sure you use the same road to do your testing. I use the same road and same starting spot to do all of my performance test. The road i use is a little up hill but its hard to find a flat and level road in Tennessee :banghead:
Im pretty sure the tune doesn't recalibrate.. You actually have to have it done. Easy way to findout- call American Muscle tomorrow and ask their customer service. They know everything.. =P
The timer is off when you switch gears because its set up to the stock gears. I used a drift box and it told me the correct time. Everything else will be good besides the speed ones
Its for sure wrong it told me I ran a 5.6 with a Procharger and that's for sure false. I'm not sure I gave up on it unless you recalibrate it which you would probably have to go to the dealership. Then they would hassle you and charge you and it still probably wouldn't get fixed
that makes me feel alot better man. I was worried for a sec
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
