DRL DISABLE?? - Mustang Evolution
Old 03-17-2013, 10:31 PM   #1
Fordboi2012's Avatar
DRL DISABLE??
Is it just my 2012 ford mustang premium edition that runs the head lights on when the car is on drive ??? HOW DO I DISABLE THAT ??
Fordboi2012 is offline   Reply With Quote
Old 03-17-2013, 10:40 PM   #2
Whitelightning's Avatar
Dealer. Or rip the headlights out.
Old 03-17-2013, 10:47 PM   #3
I tried the dealer and they dont know what it is ...
Old 03-17-2013, 11:04 PM   #4
Sanguin's Avatar
You could always unplug the factory harness, power it by a new harness and relay which hooks to the factory power switch and uses it for a trigger on the relay. That'd disable your auto-lights though. It would be a quick, safe method.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 03-17-2013, 11:42 PM   #5
CraneGuy's Avatar
Maybe it's as simple as changing your headlight switch from Auto to Off? I just tried my 2013 in the garage. With the garage lights off, I couldn't see anything from the headlights. I had the autolamp switch off, and I had the car in first gear. Haven't tried it see if they turn on when the car is rolling.
Forgive my ignorance if this works differently on the 2012's vs the 2013's!
2013 GT Premium with Track Pack
"The Devil is in the details, but so is salvation." - Admiral Hyman G. Rickover
CraneGuy is offline   Reply With Quote
Old 03-18-2013, 12:23 AM   #6
Sanguin's Avatar
Some Mustangs are special ordered with DRL lights (Canadian '10-12 models are a good example) and it's a real DRL and totally separate from the auto headlights.
Old 03-18-2013, 06:20 AM   #7
Well bad thing about that is that my car is a automatic not manual .. So yup .. And where can i get that harness switch to trigger the drl lifhts i have now !?
Old 03-18-2013, 06:51 AM   #8
bucko's Avatar
If you have a Canadian car, then you could check with your Ford parts department and see about getting a U.S. harness setup. I'll guess they are different, as I don't have the problem you are describing. There could be a relay involved as well.
Old 03-18-2013, 07:15 AM   #9
Well i live in texas so i dont think i have a canadian car but i think my best possible thing to do is go to a ford dealership that i havent been to and ask them this ... This F*ckin weird that they never turn only when the car is on PARKED
Old 03-18-2013, 08:23 AM   #10
-_- not auto lights. Drl is a half voltage light in any gear but park even with the lights in the O position
---------- Post added at 08:23 AM ---------- Previous post was at 08:22 AM ----------
It's software. Not hardware.
Old 03-18-2013, 08:34 AM   #11
So you think its a software problem @white lightning
Old 03-18-2013, 09:52 AM   #12
I've crawled the Internet and here. It used to be a fuse but in the 2011 model its in one of the many computers. I suspect the SJB because AM sells a parking light DRL wiring mod that wires into the SJB. But they can hook the computer into the port under the steering wheel.
Old 03-18-2013, 10:03 AM   #13
I didnt believe this would be so much work for the lights lol i am just thinking of staying with the factory lights !!!! Lol .. Unless i find the right way to do it ... So what happens if i buy the raxiom halo projectors from AM ? Would they be on all day when i drive huh
Old 03-18-2013, 11:31 AM   #14
there should be a procedure to turn them off, on my wife's old car you would hold the e brake in one click or something and what not it would flip them off
Old 03-18-2013, 12:22 PM   #15
And what kind of car was that inspector ???
Old 03-18-2013, 01:41 PM   #16
Nope. They flicker or won't work at all. It's all or no current. And on standby they run at 6watts.
---------- Post added at 01:41 PM ---------- Previous post was at 01:41 PM ----------
Doesn't work. Plus it'll wear down the e brake.
Old 03-18-2013, 11:48 PM   #17
CraneGuy's Avatar
Sorry, I wasn't clear. I tried it in a darkened garage because it's impossible to put the car in gear, then get out to look at the headlights. I couldn't see any tell-tale glow on the front wall of the garage. Even at half voltage, I figure I would have seen a little light reflected off the wall if DRLs were on. If they are on, they must be super dim.
Sounds like I was barking up the wrong tree anyway! Good luck to the OP- sounds like a bear to turn them off.
Old 03-18-2013, 11:55 PM   #18
Haha naw its cool man ... But **** i cant be the only with this problem ???? I just added the smoked headlight covers and tail lights and i dont want them on all the time
Old 03-19-2013, 12:03 AM   #19
pwrby4d's Avatar
If u pull the e brake up on the 13's they turn off. Most likely a switch inside. Prob can wire it so that it thinks the ebrake is up... I would start there.
pwrby4d is offline   Reply With Quote
Old 03-19-2013, 12:05 AM   #20
If i do that would it mest up my e brake for having it up while driving ???
Old 03-19-2013, 12:12 AM   #21
pwrby4d's Avatar
Dont drive with the ebrake up. I would suggest taking the console apart and seeing if their is a switch or wiring harness that you can jump to make.it think the ebrake is up so it turns off the drl's. U might be able to wire in a switch that u can toggle like an open / close circuit.
Old 03-19-2013, 12:15 AM   #22
Ummm i see well i dont know nothing about doing any wiring in the mustangs ... So i guess i am stuck with the problem still ..
Old 03-19-2013, 04:46 AM   #23
bucko's Avatar
If there is a switch on the e-brake that disables the DRL's while the e-brake is up, it should be as easy as installing a simple jumper wire between the two wires that connect to the switch! It doesn't get any easier then that for wiring!
Most software type programs rely on sensors for input, so I figured there would be a relay or switch that would disable this.
Old 03-19-2013, 07:08 AM   #24
Why jimmy rig and butcher up a new car? To me, that's just stupid. And everyone is all about a warranty, that'll definitely void it.
Old 03-19-2013, 07:15 AM   #25
Naw i am not going to ghetto rig with this new car but i am driving right now with the just parked. Lights on switch and they are in a low beam and well my fogs are on also ...
Old 03-19-2013, 09:37 AM   #26
Why are your fogs on too? I have my GT fogs off and my switch is on O so just my regular lights are on. Sometimes I don't even turn on the headlights, its enough light in the evening. But man just parking lights looks cool to me in the morning and evenings before dark
Old 03-19-2013, 10:24 AM   #27
Sanguin's Avatar
You can modify things in a way to make it completely reversible. However, activating the parking brake switch means your park brake warning will always be on in the instrument cluster. That would drive me nuts.
You can also by pass the factory harness with your own, an "add a circuit" in the fuse box, some relays and a couple wire splicers that are 100% reversible. You'll have to figure out how to wire it though. I can't draw wiring diagrams for crap, I can just read them lol
Old 03-19-2013, 11:10 AM   #28
Whitelightning naw my fogs are on if i turn them on i have the ability to turn them on or off when i want .... But the normal lights i cant they are always on .... Once i put the gear to drive they turn on but i have noticed that when the car is on drive but my light switch is on off of park lights the taillights are off and only turn on when u brake but the headlights ALWAYS ON. AND I HATE IT .. i cant enjoy my smoked headlight look during the day
Old 03-19-2013, 07:02 PM   #29
NewMtang's Avatar
So what is the big deal about having your lights on all the time? It might just help with some D*mb *ss actually see you before pulling out in front of you. It could save you from being more broken up than your car. That would be a good thing.
Old 03-19-2013, 09:02 PM   #30
Because for me, I have $60 bulbs to help see the side of the road for deer. In my case. These bulbs last only a year. See where I'm headed with this? As far as idiots, if they can't hear or see a white mustang coming, then something is wrong with them. Just .02. Plus I hate the look of it when it looks cleaner with them off
Old 06-30-2013, 05:38 PM   #31
RIstang's Avatar
Region: Rhode Island
Ever find away to fix this problem?
RIstang is offline   Reply With Quote
Old 06-30-2013, 07:55 PM   #32
NicholasP's Avatar
Just throw some hids in them and keep them on full blast all the time that way it doesn't look like half lit yellow lights haha
NicholasP is offline   Reply With Quote
Old 07-15-2013, 09:50 AM   #33
Region: Iowa
i have the same issue, did you figure anything out?
theredguy70 is offline   Reply With Quote
Old 07-20-2013, 09:07 AM   #34
RIstang's Avatar
Well I had the dealership go and shut off my drls well when they went into the computer there was no option to shut them off. So that means I some how got a canadian mustang. So go to your dealership and if you have the option they will shut off if not then u have a canadian stang. The only other option now is to change the computer
Old 07-20-2013, 12:42 PM   #35
Mines made in Michigan. (They all are) mine was a rental x plan and had to have that due to not knowing where they were shipping them. Ford chewed me out for asking and so did my local dealership. But I haven't asked my dealership I bought it from
02:28 AM
