So open differential... - Mustang Evolution
Old 03-22-2013, 01:35 PM   #1
Mustangs's Avatar
Looking to get 3.55s. Shop wanted to be sure if the car was an open or posi rear end. Thought it it was a posi. Looked it up. Maybe something like a t lock which acts as the same. You can do a burn out which means its NOT an open. But I give the vin number to the shop and they look it up and tell me it's an open differential... What do you guys think
Mustangs is offline   Reply With Quote
Old 03-22-2013, 01:43 PM   #2
Seabiscuit's Avatar
What year?
Seabiscuit is offline   Reply With Quote
Old 03-22-2013, 01:44 PM   #3
powerwhee's Avatar
2011 up mustangs all have LSD
powerwhee is offline   Reply With Quote
Old 03-22-2013, 01:55 PM   #4
Mustangs's Avatar
2011
---------- Post added at 10:55 AM ---------- Previous post was at 10:53 AM ----------
So it's not an open and it would be fine for a gear change
Old 03-22-2013, 03:56 PM   #5
Whitelightning's Avatar
Originally Posted by Mustangs View Post
2011
Why would they wanna know this anyway? Gears are gears. Been doing swaps for year now
Old 03-22-2013, 04:09 PM   #6
Mustangs's Avatar
In an open diff your car would just lose traction
Old 03-22-2013, 08:32 PM   #7
CYCLON37's Avatar
Limited slip. Not posi, not open
CYCLON37 is offline   Reply With Quote
Old 03-22-2013, 08:50 PM   #8
Sanguin's Avatar
Yep, as stated, it's a clutch-type limited slip differential. It's not open, they're smoking crap. Wouldn't surprise me if they're telling you this in order to sell you something else.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 03-22-2013, 10:58 PM   #9
Mustangs's Avatar
That's what I was afraid of. I thought I finally found a good place.
Old 03-22-2013, 11:06 PM   #10
Posi is the nickname GM gave traction lock... Each company calls it something different. Ford uses Traction lock, GM uses posi.... But yes you have Traction lock.
Old 03-23-2013, 12:20 AM   #11
So, when my dad says that it has to roll back or forward some to fully catch the two wheels, is he correct? Also said posi is for Chevy termed and will chirp the outside tire in a turn
Old 03-23-2013, 01:10 AM   #12
CYCLON37's Avatar
It is my understanding (and I'm no expert). But I believe posi is when both wheels spin at the same speed all the time. LSD is when more power is distributed to the inside wheel on a turn for better cornering. I've also heard many people say that's it's GM's phrase and such but I thought there was an actual difference between them. Right? Wrong?
Old 03-23-2013, 01:51 PM   #13
The double wheel power feature is called many things but I thought it was posi/whatever else or the lsd. Then what's a live and open axle?
Old 03-23-2013, 02:54 PM   #14
ak_stang's Avatar
Region: Alaska
Live axle refers to the whole axle assembly, if you look at your axle it is one straight bar the goes from wheel to wheel, this is not the best for cornering as the wheels are essentially connected together and when one tire hits a bump the entire rear end gets a jolt. then there is independant rear axles which each tire moves independent of one another, open axle refers to not haveing a LSD or posi or whatever, only one tire gets power
ak_stang is offline   Reply With Quote
Old 03-23-2013, 03:11 PM   #15
aegischief's Avatar
The "posi track" name is what GM calls it. Ford calls it "trac lock". American Motors called it "true lock". And if you want one from Europe, Alfa Romero calls it "Q2". All different names for what is actually by definition a Limited Slip Differential. Each company has their own unique ways of making it work. Ford uses a clutch system which has proven to be reliable over the years, especially in a 8.8 format.
Differentials that always apply power equally to both wheels are termed as "lockers", with the most common being a Detroit Locker. These are used in racing and offroad vehicles.
aegischief is offline   Reply With Quote
Old 03-23-2013, 03:26 PM   #16
Mustangs's Avatar
Regardless of all the terms for the differentials. The shop still claimed that ford said I had an open diff from my bin number. Which is BS because I just jacked my car and turned the tires and they both went the same way.
Old 03-23-2013, 03:30 PM   #17
arturo55's Avatar
So 2011+ are posi or whatever it's called
arturo55 is offline   Reply With Quote
Old 03-23-2013, 03:31 PM   #18
Mustangs's Avatar
Limited slip, but LSD is more like a posi then an open diff
Old 03-23-2013, 06:59 PM   #19
Either way. It's better than my new edge 02 rear end lol sorry I had to
02:30 PM
