anyone know where to get 2013 headlight plugs - Mustang Evolution
Old 03-23-2013, 05:24 PM   #1
hi guys,
i purchased a set of 2013 mustang xenon headlights cheap on ebay $182. with shipping from 2 different vendors, minus bulbs and ballists does anyone know what aftermarket kits will fit in these 2013 xenon headlights plus there is a 7 pin female connection in the back of headlight assemblies . ford wants $500 for a whole harness, I want to do a plug and play, I have found the pins in the rear ,I used a 9 volt battery to see what pin was what there is a ground 2 of the pins are for L E D .s one of the pins connections is for a door inside the lens which is for the high beam its electro magnetic.( like a power lock system). the others are for the hid ballists can anyone advise where to get the plugs, I want to fit into my 2011 mustang halogen system seems easy with knowing the wiring , I know what wires are for what. just need the plugs for rear of 2013 headlights assemblies and want to do an 8000 k aftermarket system cheaper than factory bulbs and ballists hope I can be advised where to get these ..
manlaw38 is offline   Reply With Quote
07:20 PM
