Grille - Mustang Evolution
Old 03-28-2013, 07:41 AM   #1
rghoover3's Avatar
Grille
Guys I know this is repeated but I want to remove my.stock grilles and dip them and was looking online some show remove bumper then CDC taped below the grille and just yanked it out.please some give experience
rghoover3 is offline   Reply With Quote
Old 03-28-2013, 08:07 AM   #2
armymedic's Avatar
I know I looked at doing this a few months back. After much deliberation I just decieded to tape off the grill, add some paper to cover some more area, and then I plasti dipped the grill. I know theres a bunch of pins and clips that need to be removed and my hands were to big to fit in the little area that I had to work with.
Seth
2013 GHIG V6
Borla ATAK Catback, Eibach Sportline Springs, Airaid CAI, Bama Tunes, JLT Oil Catch
United States Army
armymedic is offline   Reply With Quote
Old 03-28-2013, 10:06 AM   #3
rghoover3's Avatar
Did you upper and lower send a picture please my car is the light silver with mca grill and tires so I thought about doing both
Old 03-28-2013, 10:53 AM   #4
armymedic's Avatar
I just did the upper grille to cover the chrome pieces. I did not plasti dip the lower grill at all. Honestly it's hard to tell the two apart as far as one being plasti dipped and the other not.
ID:	98972   Click image for larger version
Seth
2013 GHIG V6
United States Army
Old 03-28-2013, 11:00 AM   #5
rghoover3's Avatar
See mine looks different
Old 03-28-2013, 11:18 AM   #6
armymedic's Avatar
ahhh gotcha ... you still wouldnt have to remove them though. Just tape the areas off and do a few light coats of the black plasti dip
Seth
2013 GHIG V6
United States Army
Old 03-28-2013, 11:43 AM   #7
BlackedStang's Avatar
Damn that looks good
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 03-28-2013, 11:54 AM   #8
rghoover3's Avatar
Thanks man do you think it would good blacked out matching.grill
Old 03-28-2013, 01:52 PM   #9
crazychink's Avatar
If you're still looking into removing bumper. CJpony got a pretty good video on youtube
crazychink is offline   Reply With Quote
Old 03-28-2013, 02:20 PM   #10
rghoover3's Avatar
I saw that bit I hate to CDC just yanked hard it came out
Old 03-28-2013, 04:03 PM   #11
Hmiller's Avatar
Send a message via AIM to Hmiller
This is the same video I used personally I love my CDC performance grille
---------- Post added at 05:03 PM ---------- Previous post was at 04:59 PM ----------
I wasn't able to do this on the V6 grille like they did on the GT. The spaces are different.. not sure how the MCA relates. It's not hard to remove the whole bumper plus it's a "safer" way to do it. Also if you get the CDC and have the V6 bumper you will have to modify it. You will have to cut two support (whatever they are) plastic pieces off the bumper. I found that if you didn't cut them off the CDC wouldn't clear to be snapped into the clips. I don't think it will be as easy to cut them off with the bumper still on ... Just my .02
VOTE For MOTM!!!!!!
Hmiller is offline   Reply With Quote
Old 03-28-2013, 04:43 PM   #12
rghoover3's Avatar
I'm just dipping my grille
Old 03-28-2013, 04:51 PM   #13
crazychink's Avatar
I didn't want to deal with over-spray into the radiator so I took off my bumper.
ID:	99035   Click image for larger version
ID:	99037   Click image for larger version
Old 03-28-2013, 04:54 PM   #14
curtin1991's Avatar
Send a message via ICQ to curtin1991
I'd just pull the front bumper to be able to get to th back of the grille for easy removal. I have removed mine lots of times it takes 15 mins to pull off going slow. Or just yank it out like others have done . Not sure I would though .
Corey
curtin1991 is offline   Reply With Quote
Old 03-28-2013, 09:24 PM   #15
JimC's Avatar
No need to take the bumper off to remove the upper grille. It is held in with push clips and so all you need to do is tape off around the grille to protect the paint and pull straight out. That is how CDC did it when they did the promotional make over of my car in Mustang Alley during the Woodward Dream Cruise last August.
And yes, for the performance grille you have to cut the center section out
because the performance grille is completely open:
You can see the center is blocked off on the stock grille (at least for the MCA and I believe that the center horse on the stock grille also has the big block). You can also see the push pin type clips in this picture.
JimC is offline   Reply With Quote
08:50 PM
