3.73 Gears - Mustang Evolution
Old 03-30-2013, 08:41 PM   #1
Shack's Avatar
3.73 Gears
Is first gear pretty much worthless? And is getting traction an issue?
Shack is offline   Reply With Quote
Old 03-30-2013, 09:10 PM   #2
Charlie_santos's Avatar
Na only with 4.10's is 1st useless lol
Old 03-30-2013, 09:53 PM   #3
Gdocumet's Avatar
Ford's 3.31 is perfect for me, a daily driver, but if you want to be losing traction anytime you rev it past 2k rpm then go with the 4.1
Gdocumet is offline   Reply With Quote
Old 03-31-2013, 11:05 AM   #4
rebeltx's Avatar
Just the 3.73 gears aren't too bad. If you punch it in first with traction control off you will spin the tires thru most of first. With a tune and gears your car will feel like a new beast. if you put a drive shaft in then you can forget first gear. I was doing ok with the 3,73 gears until I put in an aluminum drive shaft, now I can spin 2nd off the line, 1st is useless for anything less than showing off.
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 03-31-2013, 11:09 AM   #5
Shack's Avatar
Awesome info. Thanks!
Old 03-31-2013, 01:55 PM   #6
David Young's Avatar
I went from 3.31 to 3.73 gears. I have an automatic. I wish i had gone with 4.10 or 4.56 gears. First gear is very useful and yes, i have no traction
David Young is offline   Reply With Quote
Old 03-31-2013, 10:00 PM   #7
2011 Kona Blue's Avatar
I went from 2:73 gears to 3:73 gears and have an automatic. I'm running on the factory Michelin 215/65/17 tires along with a one piece aluminium driveshaft from AM and I have zero traction issues. Pulls hard off the line from dead stop.
Old 04-01-2013, 12:05 AM   #8
rebeltx's Avatar
Do you have a tune? Or lower control arms or what? Because I have no traction when I launch hard at the track
Old 04-01-2013, 12:26 AM   #9
Adamp1's Avatar
What difference did you feel when installed the drive shaft? My car is an auto too and I am contemplating putting in a DS.
2012 V6 AUTOMATIC 3.7 / MAGNA FLOW MUFFLERS / 3.73 GEARS / STEEDA CAI / 91HYBRID OCTANE TUNE / STRUT BAR / GUNMETAL MATTE METALLIC RACING STRIPE / BBK SHORTY HEADERS / BBK 73MM THROTTLE BODY
Adamp1 is offline   Reply With Quote
Old 04-01-2013, 04:19 AM   #10
I have the factory 235/50-18 with 18,000 miles on them. A little over half worn out. I can start out in second gear (automatic) with no tire spin but when second gear hits its power band, i start fish tailing. I hope when i buy new 255/45-18 Cooper Zeon tires later this summer will help.
Old 04-01-2013, 08:25 AM   #11
I have a Sct Bama tuner. I'm running 91 Hybrid Tune and currently do not have any upper or lower control arms. When at dead stop, I just floor that gas pedal and it shoots off hard. Little spin, maybe a few little chirps . Lol. I have an automatic
---------- Post added at 09:25 AM ---------- Previous post was at 09:21 AM ----------
I noticed the car shifts smoother with the aluminium driveshaft. Now with the aluminium driveshaft in I can have no worries of traveling 145 mph without the worry or possibility of it exploding through
Old 04-01-2013, 09:54 AM   #12
bucko's Avatar
Outside of tracking the car, where are you going to do 145 MPH?
Old 04-01-2013, 12:16 PM   #13
Private track of course. same place that the other members do that speed.
Old 04-01-2013, 12:40 PM   #14
powerwhee's Avatar
My traction is generally pretty good with my 3.31 gears and 245 45 18 potenza tires. Unless I launch above 2k than it'll spin thru all if first
powerwhee is offline   Reply With Quote
01:01 PM
