install questions help me? - Mustang Evolution
Old 03-31-2013, 12:49 PM   #1
13savage6's Avatar
got my lethal x-pipe delete in and cant find any install instrut on it, thought one of u guys be abe to help me.
mods- eibach sportline springs, camber bolts, j&m panhard bar, pypes pipebombs, upr short shift kit, 92 hybrid bama tune , JLT cai ,lethal perfomance o/r x-pipe , pypes m-80 mufflers.
13savage6 is offline   Reply With Quote
Old 03-31-2013, 12:55 PM   #2
Billymich's Avatar
Should be pretty straight forward, exhaust is pretty easy. The toughest part is getting the old hardware off as it rusts a lot from heat and water. Get a lot of penetrating spray
Old 03-31-2013, 01:17 PM   #3
13savage6's Avatar
i see thnks bro have done this mod and if so how long did i take you? do u think the new bbk shorty headers fit after i install these
Old 03-31-2013, 01:54 PM   #4
Charlie_santos's Avatar
Its simple, go under ur car after u lift and put it on stands, spray the **** outta the mid pipe bolts on the midpipe to headers section and mid pipe to OTA Pipes, after 10min of letting them soak just unbolt them with a friend to hold it and it should slide out easy. And yes those "useless" shorties will bolt up fine as replacement eye candy headers. I say useless and eye candy because thats all there good for.
Old 03-31-2013, 02:03 PM   #5
13savage6's Avatar
dam charlie ur mean but any way thanks, i am planning on getting the shorties so i can use them for single or twin turbo set up, so i dont think its gonna be useless in the long run. what do u think.
Old 03-31-2013, 02:18 PM   #6
Yea unless going Turbo then they are literally only good for eye candy or replacements for cracked headers. I wanna go turbo myself but im waiting on a fellow member to see what final results he gets with his crazy Procharger setup.
---------- Post added at 02:18 PM ---------- Previous post was at 02:18 PM ----------
Do you plan on getting forged internals too?
Old 03-31-2013, 02:29 PM   #7
13savage6's Avatar
turbo that ish from my understanding u can only go so far with a procharger setup like smaller pulleys and stuff, but wit a turbo setup the possibilities are almost endless, and im keeping my v6.
as far as forged internal and cams, ported heads yes they are a must and will be starting to mod them here pretty soon. ive been calling around and surfing the web, like mmr and super six motersports. any other leads on these type of mods charlie?
Old 03-31-2013, 02:32 PM   #8
For cams a shop here locally has a sister shop that does custom cams thats it besides mmr and super six
Old 03-31-2013, 02:44 PM   #9
13savage6's Avatar
do u think mmr s 3.7 V-6 Forged rotating assembly is really good for up to 1200hp? that would be worth 2000$huh .also how much do think it would cost for install
Old 03-31-2013, 02:58 PM   #10
Id get my install free lol but it is a bigger job but i would expect it to be a pretty penny bro. I think the mmr internals could handle 1200 my friend who is twin turbo on his 08 GTCS and is pushing 900 to the wheels has their intake mani and internals .
Old 03-31-2013, 03:17 PM   #11
13savage6's Avatar
how would you get ur install free?
Old 03-31-2013, 03:23 PM   #12
Black on Boss's Avatar
He gets everything for free !
Old 03-31-2013, 03:29 PM   #13
13savage6's Avatar
prove it and then ill believe it
---------- Post added at 02:29 PM ---------- Previous post was at 02:25 PM ----------
hey black on black how haerd was ur lethal performance o/r h-pipe install? got any tips?
Old 03-31-2013, 03:30 PM   #14
Sponsored by HPS here in El Paso Tx. Me and my Friend Drake are Sponsored. Ill either pay close to nothing or free entirely. Got my gears, DS, LCA, UCA, Panhard bar, Springs. Free lol just have to put a magnetic decal on my car when i run the track.
---------- Post added at 03:30 PM ---------- Previous post was at 03:30 PM ----------
Lol i get good deals bro!!!
Old 03-31-2013, 03:34 PM   #15
13savage6's Avatar
hook it up or else..............jus kiddin.
Old 03-31-2013, 03:38 PM   #16
Lol yea prove it and Charlie pretty much summed it up, its a pretty straight forward install, but make sure you shoot the header bolts with some lube. I didn't and had to replace a bolt
Old 03-31-2013, 03:44 PM   #17
13savage6's Avatar
im gonna go on base and rent a stall with a lift so that should help plus they got every thing i need.
hey charlie you dont have to lie to kick it bro. lmao
Old 03-31-2013, 03:48 PM   #18
I did mine on jack stands
Old 03-31-2013, 03:55 PM   #19
13savage6's Avatar
did you use abreaker bar and extesions
Old 03-31-2013, 03:59 PM   #20
U have to take a class for the lifts bro my buddy goes there alot. And no need for a breaker bar ur car is fairly new. Spray some liquid wrench n let it soak
Old 03-31-2013, 04:02 PM   #21
13savage6's Avatar
no class needed last time so it should be cool . liquid wrench?
Old 03-31-2013, 04:10 PM   #22
They require them here at Ft Bliss :/ and yea go to autozone its called liquid wrench and is 10X better than WD40
Old 03-31-2013, 04:20 PM   #23
13savage6's Avatar
not over here in wa. ft.lewis they asked me if i knew what was doin and sent on my way.just make sure set the lift points, lift 4 feet push down on the car front and back to make sure its stable then lift to desired point then lower till it sits on the locks.i went to wyotech years ago.
Old 03-31-2013, 04:22 PM   #24
Sweet! Over here they have way too much safety policies its lame
Old 03-31-2013, 04:40 PM   #25
+1 no breaker bar needed unless ur a 12 yo
Old 03-31-2013, 04:42 PM   #26
LOL^^^
Old 03-31-2013, 05:56 PM   #27
13savage6's Avatar
ok ok what about extensions cuz i just found out that shop on base is closed so i bought a low profile jack and jackstands.
Old 03-31-2013, 06:07 PM   #28
You will need A LOT of extensions or a really long one
06:04 PM
