Need tips for X-pipe install - Mustang Evolution
Old 04-03-2013, 10:24 PM   #1
Marc3.71994's Avatar
How do I get to and undo the bolts that connect the manifolds to the stock h-pip?
Marc3.71994 is offline   Reply With Quote
Old 04-03-2013, 11:37 PM   #2
Charlie_santos's Avatar
Jack up the car and put it on stands, follow the midpipe up and u will see the flanges, spray them with WD40 or Liquid Wrench. Then just unbolt it. Pretty straight forward bro
Old 04-03-2013, 11:50 PM   #3
Having clearance issues just trying to get the ratchet on the bolts.
Old 04-04-2013, 05:26 AM   #4
alrefire's Avatar
i'll be following this closely
I'm doing my off road h pipe today
Old 04-04-2013, 06:45 AM   #5
Whitelightning's Avatar
Yours isn't bolt on is it?
Old 04-04-2013, 06:47 AM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Try a really long extension and a uni-wiggle haha
2012 Kona Blue 3.7L V6:
Old 04-04-2013, 07:53 AM   #7
alrefire's Avatar
It says it includes all hardware for installation
It should bolt up, if not I'm calling back requesting a welder ;p
Old 04-04-2013, 08:23 AM   #8
Where did you get it?? I've only found weld ins
Old 04-04-2013, 08:37 AM   #9
Abominable Mustang
WhoDat's Avatar
Region: Alaska
The only bolt-on h-pipe I've found is the one from Lethal Performance, but it's for stock manifolds/shorty headers.
Old 04-04-2013, 10:07 AM   #10
alrefire's Avatar
That's what I got
I don't wanna upgrade to long tubes, because it'd be kinda pointless if/when I go turbo ;p
Old 04-04-2013, 10:09 AM   #11
That's what I got
Install ur hpipe i wanna hear the exhaust improvement
Old 04-04-2013, 10:13 AM   #12
alrefire's Avatar
I will buy I won't be able to make a good vid until Saturday
I'm dropping off my car ought after the install to remove rear tint and to fix my push to start button.
Old 04-04-2013, 10:14 AM   #13
What happened to ur push to start? My buddy has one and is gna sell me his for $50
Old 04-04-2013, 10:16 AM   #14
alrefire's Avatar
When I wrapped the chrome I managed to destroy my push to start.
I bought a new module for $20 and that didnt fix it.
I must've either pulled out a wire somewhere, or really f**ked it up :p
Old 04-04-2013, 10:18 AM   #15
Oh damn! Lol that sucks hahaha
Old 04-04-2013, 10:42 AM   #16
alrefire's Avatar
I'm replacing te bright blue led with a red one!
Old 04-04-2013, 11:10 AM   #17
The button is blue? So u would get a yellow color no?
Old 04-04-2013, 12:21 PM   #18
alrefire's Avatar
Idk
The button glows red
Well it's supposed to
Old 04-04-2013, 01:41 PM   #19
I found nothing but GT stuff as far as h pipe
---------- Post added at 02:41 PM ---------- Previous post was at 02:41 PM ----------
That's what I got
I just wanna have a cooler engine and more sound.
Old 04-04-2013, 02:30 PM   #20
alrefire's Avatar
Yea, but I be buying pipes just to replace em
Granted I'm probably gonna have to do that with the h pipe but o well
200>600
As far as spending goes
Old 04-04-2013, 03:03 PM   #21
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Here ya go: http://www.lethalperformance.com/201...ad-h-pipe.html
Old 04-04-2013, 06:21 PM   #22
alrefire's Avatar
I'm arch trying to get it out now :p
Old 04-04-2013, 09:04 PM   #23
alrefire's Avatar
Well, I got the bolts that connect to the manifold out, but not my o2 sensors, I didnt have the right size wrench >:O
Will resume Saturday tho
Old 04-04-2013, 11:42 PM   #24
Nice, what did u use to get the bolts that connect to the manifold out?
Old 04-05-2013, 06:30 AM   #25
alrefire's Avatar
My hands, a ratchet, and a whole lot of wd40
I had no clue my arm could bend in that many ways....
Old 04-05-2013, 07:53 AM   #26
Haha alright, did u do it from top or underneath the car?
Old 04-05-2013, 08:17 AM   #27
alrefire's Avatar
Everything from underneath with the exception for the upper bolt that connects the manifold to the midpipe on the passenger side
Old 04-05-2013, 08:20 AM   #28
I would advise to use liquid wrench, its like WD40 but penetrates alot more and quicker on rusted on bolts. I sprayed all my bolts when i did my header install and waited 10min for them to soak and all my bolts cane off easy. Even my header bolts. It really does work well for me.
Old 04-05-2013, 08:21 AM   #29
alrefire's Avatar
I'll have to get that when I upgrade suspension :p
Old 04-05-2013, 08:22 AM   #30
Holy **** does it help with that too!! I used it for my LCA, UCA, front/rear sway bars etc
Old 04-05-2013, 08:22 AM   #31
alrefire's Avatar
A tip for the OP
Rent an o2 sensor remover tool BEFORE you get started
Old 04-05-2013, 08:24 AM   #32
A tip for the OP
Good idea!!
Old 04-05-2013, 08:31 AM   #33
Great info thanks guys
Old 04-05-2013, 09:31 AM   #34
alrefire's Avatar
Just be carefull while removing the bolts
I went ham on one and made a little spark, it's scared the sh*t out of me, because I used wd-40
Also
Remie the negative battery cable, when you get ready to remie the o2 sensors
Old 04-05-2013, 09:34 AM   #35
Also
Lnfao dont go ham bro thats just too hardcore lol
08:06 AM
