Octane - Mustang Evolution
Old 04-07-2013, 05:16 PM   #1
03fastblack's Avatar
Octane
My brother has a 2012 v6 and wondering what's the highest octane he can run
03fastblack is offline   Reply With Quote
Old 04-07-2013, 05:25 PM   #2
nhcowboy's Avatar
Octane recommendations (v6)
Your vehicle is designed to use
“Regular” unleaded gasoline with a
pump (R+M)/2 octane rating of 87.
Some stations offer fuels posted as
“Regular” with an octane rating
below 87, particularly in high altitude areas. Fuels with octane levels below 87 are not recommended.
Do not be concerned if your engine sometimes knocks lightly. However, if it knocks heavily under most driving conditions while you are using fuel with the recommended octane rating, see your authorized dealer to prevent any engine damage
Octane recommendations (5.0L V8 engine)
Your vehicle will run normally on 87 octane regular fuel without damaging the engine, but premium fuel with an octane rating of 91 (R+M)/2 or higher is recommended for best overall performance.
For Shelby GT500 octane requirements, see the Shelby GT500 Supplement.
---------- Post added at 06:25 PM ---------- Previous post was at 06:24 PM ----------
In other words, if you have an untuned V6, you won't see much benefit from higher octane fuel.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 04-07-2013, 06:13 PM   #3
kdbdallas's Avatar
Would a higher octane be "better" for the engine, even if there is no noticeable difference? (Like in the "life span" of the engine)
kdbdallas is offline   Reply With Quote
Old 04-07-2013, 06:14 PM   #4
Or gas mileage
Old 04-10-2013, 10:13 AM   #5
Warbot's Avatar
Or gas mileage
Hey your inbox is full bro just letting you know haha
Warbot is offline   Reply With Quote
Old 04-10-2013, 12:25 PM   #6
if the engine can not modify its tune to burn the higher octane differently you get zero use out of it, octane is used to incease the amount of timing the car can handle without detonation. If your car is tuned to go up to say 93 then it will help. Older cars run 87 and have only one tune (does not change) so running anything else is useless.
Old 04-10-2013, 12:35 PM   #7
kdbdallas's Avatar
I guess I can save some money by only putting 87 in my 2013 V6 (no modifications or tune changes)
Old 04-11-2013, 02:11 AM   #8
ak_stang's Avatar
Region: Alaska
You can find this on the internet but supposedly the stock tune will advance the timing until knock or pinging occurs then back it off, higher octane fuel will theoretically boost power, but we are talking like 5 HP Max, I know I've seen dyno charts somewhere
ak_stang is offline   Reply With Quote
Old 04-11-2013, 02:34 AM   #9
The Puma's Avatar
So if I'm tuned for 93, it's safe to use, right? Even if the engine was designed for 87...
The Puma is offline   Reply With Quote
Old 04-11-2013, 04:09 AM   #10
audioAl's Avatar
The winner is
You are right 5 HP increase with 93 octane fuel, K&N drop-in maybe another 5,
maybe not. The new "Cyclone" 3.7 DOHC is a strong motor, enjoy!
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 04-11-2013, 04:26 AM   #11
MrMike's Avatar
While it won't make nearly as much power as it would if it was tuned, you will see some minimal gains. Our engines can advance and ****** timing. http://v6mustangperformance.com/news...ine-explained/
MrMike is offline   Reply With Quote
Old 04-11-2013, 08:10 PM   #12
UltArc's Avatar
I appreciate this post and link, but I missed where it says about changing timing. Could you expand on it?
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 04-11-2013, 08:50 PM   #13
MrMike's Avatar
Ford calls Ti-VCT, variable valve timing on both intake and exhaust valves, a feature that allows a full 60 degrees of cam timing adjustment on the intake side and 50 degrees on the exhaust side. Meaning when using higher octane (premium or race fuel) the knock sensor will advance ignition timing to produce more power until they detect knock then will ****** it to optimize power and fuel economy. Being that I'm not an engineer nor claim to be I assume that is why they say the engine will produce considerably more power than the stock sae numbers. Like I stated it I don't think it will be significant gains compared to tuning but should be a little higher than stock #s. Is it worth the extra $ per gallon? Maybe, maybe not. Hope that helps a little, that's what I get out of it.
Old 04-11-2013, 09:39 PM   #14
clamphier's Avatar
It is better for running through your injectors and everything and it burns cleaner. I even use 93 in my 2000 expedition with almost 200000 miles. It won't make your car worse and trust me our cars love higher octane. It will even run c16 without modification our cars are incredible
clamphier is offline   Reply With Quote
Old 04-12-2013, 04:00 AM   #15
bucko's Avatar
The Ford engineers did a great job to design the 3.7 to run with 87 octane. A huge reason why I bought it, as I drive quite a few miles per week, and love the performance and fuel economy I get on 87 octane fuel. A $12.00 bottle of techtron fuel additive every 5 thousand miles will keep your injectors and fuel system clean.
Run the 87, and try to use decent grades of fuel, such as Shell, Mobile, etc, as they add fuel additives for cleaning in all their grades.
If you bought a tuner and have a tune loaded that runs with the higher octane, then yes, run the higher octane fuel. Running 93 octane in a stock setup is not going to be worth the extra 20 or 30 cents a gallon IMO.
Old 04-12-2013, 06:30 AM   #16
clamphier's Avatar
If you get the Lucas fuel injection cleaner it works a lot better than the techron and its cheaper. Just thought I'd let you know we tested it out the other day..
Old 04-12-2013, 07:00 AM   #17
Well said..
Old 04-12-2013, 09:12 AM   #18
kdbdallas's Avatar
Thanks for the info!
When mine gets back from the repair shop, and I can finally get the chance to take it from 4k to 5k (total) I will give that fuel additive a try.
How are you supposed to use it?
Put it in on an empty tank and then fill?
Mid tank?
Or full (or almost full) and then that?
Old 04-12-2013, 10:28 PM   #19
Midnight2012's Avatar
Mid tank?
I'm curious also. The manual says not to use additives.
Midnight2012 is offline   Reply With Quote
Old 04-12-2013, 10:35 PM   #20
clamphier's Avatar
Fuel additives don't do crap its a waste of money I promise. Fuel injection clean is about the only thing that works. Octane booster does not even do a full octane higher
Old 04-12-2013, 11:00 PM   #21
kdbdallas's Avatar
And this here is the problem.. one person says "this is this" and then someone else says "no, this is that"
Anyone else have insights?
We can go democracy on this thing and say the side with the most votes win
Old 04-13-2013, 05:19 AM   #22
MrMike's Avatar
For the few bucks your gonna spend on octaine booster you could have just put in premium. No?
Old 04-13-2013, 07:00 AM   #23
clamphier's Avatar
+111 and you are actually getting the octane
Old 04-13-2013, 09:49 AM   #24
kdbdallas's Avatar
What about fuel additives?
2013 V6 Black
"These cars are meant to be driven", so enjoy the hell out of all of it - not just the look of it when it is all clean" - Carroll Shelby
Old 04-13-2013, 09:59 AM   #25
clamphier's Avatar
Well it depends on what kind of additives you are doing
Old 04-15-2013, 08:52 PM   #26
ArtU's Avatar
Just an FYI, Techron is patented, about the only cleaner recommended by chemists that know, and its only 6.96 at Wally-World. Last week it was marked 4.97 at my local Wall-Mart and I took the last two bottles on the shelf. I have been using it in my Silverado for a few years now.
Next issue, manual says not to use additives. Well Shell and Chevron and other major grades of fuel put additives in the gas, so better not put gas in the car then since the manual says not to use bargain fuels and use major band names
Next issue, how do you "really" know Lucas cleans fuel injectors better than Techron? Just asking, not saying
Next issue, folks have had to buy Octane booster for decades since Tetraethyl Lead went the way of the Dyna Soar [pun intended to those that know AeroSpace]. Some brands are probably & likely crap. But are you stating to the NOS folks who say they give 3 points of Octane on their branded octane booster product that they are not being truthful?
Again, Just asking, not saying
Old 04-15-2013, 09:03 PM   #27
clamphier's Avatar
Because we have two twin cars at the shop like literally almost the same amount of miles and put one in one car one in the other and tested how much gas and how clean it was came put and Lucas's was better tested it again in 5,000 miles and way less gunk. I would say not truthful just trying to make money that's how the businesses world works its unfortunate but its how it is
Old 04-15-2013, 09:26 PM   #28
ArtU's Avatar
Well, I have worked close to top brand marketing and advertising in America for almost 2 decades. Most (but never all) brand market companies have real substantial proof to backup their marketing claims.
Are you saying again, NOS 3.1 Octane boost claims are not true?
4 out of 5 Car Enthusiasts want to know
On the Lucas issue I can't dispute what you are testing, Trust in God, all others bring data; and that is what you are doing. Just however that I know several chemists in industry have said in the past Techron was the only Injector cleaner that works. Looks like from your testing and if the data holds, now there will be two.
Old 04-15-2013, 09:30 PM   #29
clamphier's Avatar
Well I'm not saying completely false it might help but not enough for what it costs. Well I've been working on cars for a long times and I am that 1 of of the 5 that doesn't agree
Old 04-15-2013, 09:43 PM   #30
MrMike's Avatar
+1 I'm also 1 in 5. That said its not a bad thing but ill just put in 94.
Old 04-15-2013, 09:53 PM   #31
clamphier's Avatar
Where do you get 94?! I've never heard of that
Old 04-15-2013, 09:57 PM   #32
MrMike's Avatar
Petro Canada! They call it "ultra"
Old 04-15-2013, 10:02 PM   #33
clamphier's Avatar
Can you tell the difference?
Old 04-15-2013, 10:06 PM   #34
MrMike's Avatar
I feel better throttle response compared to 87, but only put it in once in a while.
Old 04-15-2013, 10:09 PM   #35
clamphier's Avatar
How much more is it?
06:42 AM
