Fun with Math: Drive Shafts - Mustang Evolution
Old 04-09-2013, 09:00 AM   #1
DEvermore's Avatar
Region: Iowa
So I just replaced my 2.73 gears with 3.73 and am thinking about that drive shaft.
I understand the factory ecm limits us to 120 mph for good reason; the factory drive shaft isn't rated for higher speeds.
But I changed out the gears to 3.73. That means the shaft is rotating at a higher rpm at the same speed than before. Does this mean I need to keep the car below about 88 mph?
Maybe I did the math wrong, too. I was thinking that going 88 mph with 3.73 gears is roughly equivalent to 120 mph on 2.73 gears.
The reason this is on my mind is because I was thinking about taking the car to the track to see what differences the new gear, CAI (and hopefully Bama's custom tunes, whenever they are done with them) make. But if that driveshaft will make that idea really dangerous, then I need to reconsider.
Thoughts? Am I way off here? Or have I got it about right?
2017 GT350 w/electronics package.
DEvermore is offline   Reply With Quote
Old 04-09-2013, 09:07 AM   #2
2013mustang5.0's Avatar
You have gotten it about right. It's actually 93mph to be excact . And yes if I were you, to play its safe you should get an aluminum one piece drive shaft
2013 mustang 5.0 track pack(first mustang)
2013mustang5.0 is offline   Reply With Quote
Old 04-09-2013, 09:40 AM   #3
bucko's Avatar
Good point with the one piece drive shaft. I've always wondered why folks go through spending the money on them for the street; but changing the rear gear such as you did now makes sense, as you are turning a much higher RPM with your setup.
Old 04-09-2013, 12:24 PM   #4
Site Sponsor
Sponsor
AMWill's Avatar
Not a bad idea to change the driveshaft. I've always been for taking the extra safe route and building the car to handle much more than it produces. That's a good way to keep yourself out of some serious trouble, IMO!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 04-09-2013, 12:45 PM   #5
CYCLON37's Avatar
Shane
I think the whole driveshaft thing may have been blown up to be more of a problem then it is but it's always better to be safe than sorry. Aftermarket shafts have failed too so I'd recommend the safety loop if anything.
CYCLON37 is offline   Reply With Quote
Old 04-09-2013, 12:54 PM   #6
The Blue Dragon
GrabberBlue5.0's Avatar
That raises another question for me, I wonder if the speed limiter was set to 120 for the pony package cars with 3.31's or for cars with 2.73's? Or both? If it was for the 3.31's then your be good to go a little faster.
This doesn't really do much for your question I guess but I'm just curious. Either way I would recommend a one piece DS
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-09-2013, 01:14 PM   #7
Whitelightning's Avatar
I made a thread discussing this. Too bad no one searches these days. But I'm doing 3.31 just for the safety.
---------- Post added at 02:14 PM ---------- Previous post was at 02:12 PM ----------
Also asked this. No one answered.
I'd assume the 2.73 since most came with it and not everyone will be buyin the performance pack.
Old 04-09-2013, 01:39 PM   #8
CYCLON37's Avatar
I believe that the limiter was set because of the speed rating of the base tires. I'm sure the weak DS kept it limited on the PP and such.
Old 04-09-2013, 02:00 PM   #9
DEvermore's Avatar
Region: Iowa
Thanks for all the replies, everyone, good conversation. I'm putting the al drive shaft on my to-buy list as soon as I can manage it. I want to see how things settle out first, as I'm still waiting for a working tune from Bama for my Diablo Intune. First two have failed -- turned off speedo and car accelerates with a roar when I take my foot off the accelerator. Putting around on stock tune for now... >.< Must... be... patient... argh. But that's a different topic.
07:09 AM
