Direct Injection - Mustang Evolution
Old 04-15-2013, 06:13 PM   #1
tgmeyer's Avatar
Direct Injection
Curious how exactly efficient is direct injection and what are the benefits I'd see from it? I'm referring to if it was in the 3.7L and what would be the benefits?
tgmeyer is offline   Reply With Quote
Old 04-15-2013, 06:52 PM   #2
Sanguin's Avatar
DI provide direct atomization of the fuel where it's needed. This fuel being spray directly into the combustion chamber also cools it. These two work together to create more power. The fuel provides more efficient ignition and because the chamber is cooler, you can advance timing to get even more power from the same fuel before pre-detonation occurs.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 04-15-2013, 07:20 PM   #3
tgmeyer's Avatar
Anyway you can add direct injection? It's looking like the 15's will get it most likely and wondering if it's really that great?
Old 04-15-2013, 07:29 PM   #4
Sanguin's Avatar
It makes it harder to swap injectors for special builds because not many DI injectors are available. There is no way to add it without drastically modifying the heads or just head swapping. There has to be another hole in the head for the injector to protrude into the combustion chamber. I think they're said to be worth 30-40hp extra.
Old 04-23-2013, 09:14 PM   #5
tgmeyer's Avatar
What do you think the bump in horsepower and MPG with direct fuel injection? Worth waiting for? Super big upgrade or just kinda?
Old 04-23-2013, 11:04 PM   #6
clamphier's Avatar
[QUOTE="tgmeyer;1622321"]What do you think the bump in horsepower and MPG with direct fuel injection? Worth waiting for? Super big upgrade or just kinda?[/QUOTE
Not much if any at all. I'd say kinda there's limitations for both set ups
clamphier is offline   Reply With Quote
Old 04-24-2013, 09:27 AM   #7
tgmeyer's Avatar
So is Sanguin's comment wrong? What I don't want to do is buy a 13 V6 and find out that 2015's are going to kick my butt and get significantly better MPG's, otherwise I'll be kicking my own butt. This is the time to get some crazy deals on 13's though.
Old 04-24-2013, 09:47 AM   #8
clamphier's Avatar
I don't even like how the 15s look. The 13s stock get 25ish average I don't see how it can be much better
Old 04-24-2013, 10:10 AM   #9
JimC's Avatar
How do you know what the
---------- Post added at 12:10 PM ---------- Previous post was at 12:09 PM ----------
How do you know what the 2015 looks like? Ford hasn't released any pictures and has said that the photoshop pictures aren't correct.
JimC is offline   Reply With Quote
Old 04-24-2013, 10:22 AM   #10
clamphier's Avatar
Well I was basing it off those, I thought they had a mach up of it, looks like a Taurus
Old 04-24-2013, 10:59 AM   #11
JimC's Avatar
09:17 PM
