what the said dealership - Mustang Evolution
Old 04-24-2013, 09:33 PM   #1
arturo55's Avatar
i went to the dealership but i had a issue when i turn my car on from a cold start it makes a noise between the rpms of 600-1000 and i dont know how to explain it its like a whining noise and it wasnt making that noise before and they said everything was fine but its still making the noise
arturo55 is offline   Reply With Quote
Old 04-24-2013, 10:17 PM   #2
Sanguin's Avatar
Might be the idle air control valve making noise adjusting the idle until it steadies. GM 3800s are funny. They make a horrible, growling sound from an open intake until they warm up. Perfectly normal but sounds nasty.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 04-24-2013, 11:58 PM   #3
elliottxspyder's Avatar
Wow its crazy you mentioned that, had a 97 camaro with the 3.8 and made that horrible gurgling sound when warming up and never knew what it was
elliottxspyder is offline   Reply With Quote
Old 04-25-2013, 06:20 PM   #4
arturo55's Avatar
i dont know if i should change the belt or my friend said it can be the pully bearings
Old 04-25-2013, 10:12 PM   #5
Sanguin's Avatar
Belts normally chirp or squeal. Pulley's normally squeal too. The only thing that usually whines on a car is the power steering pump, but we don't have one.
Old 04-25-2013, 10:33 PM   #6
rebeltx's Avatar
Huh? No power steering pump? Learn something every day I guess
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 04-25-2013, 10:34 PM   #7
pwrby4d's Avatar
An altenator going bad will whine too... You could try pouring a cup of water on the drive belt as it is turning. If the sound goes away it could help diagnose at least where the sound is coming from and if the belt is slipping... Is it loud? Does it change pitch when revved? Get louder when revved?
pwrby4d is offline   Reply With Quote
Old 04-25-2013, 11:03 PM   #8
Sanguin's Avatar
Yep, we have electric power steering, not hydraulic. An electric motor assists you in our car, like many new vehicles. However, many professional driver's have said the one utilized in the Mustang is the best. Probably why a new Porsche is using a Ford steering system.
Old 04-26-2013, 07:24 AM   #9
arturo55's Avatar
its not loud but you can hear it and it only happens at 1000 rpms from a cold start
Old 04-27-2013, 01:51 PM   #10
arturo55's Avatar
Old 04-27-2013, 01:59 PM   #11
redbeast0712's Avatar
Region: Nevada
The cool thing about electric power steering in our cars is that you can adjust the feel of the steering. I think it's awesome!
redbeast0712 is offline   Reply With Quote
Old 04-29-2013, 05:12 PM   #12
arturo55's Avatar
I still need help with this
Old 04-30-2013, 12:15 AM   #13
BigClaunch's Avatar
Can you do it in base models and if so how?
BigClaunch is offline   Reply With Quote
Old 04-30-2013, 01:45 AM   #14
Schram1's Avatar
This is called cold tick nothing wrong with it. i remember it cylinder 3 i have same thing
Borla catback s-type Borla Long tube off road x pipe
Jlt carbon fiber intake / BBk TB
J&M panhard bar J&M extreme lower control arm /relo
koni STR.T RTR wheels NT555/ Shelby Baer 6P
DSS Aluminum 3.5/3.73 gears
https://www.youtube.com/watch?v=1cm4Di-zmZA
Schram1 is offline   Reply With Quote
Old 04-30-2013, 06:27 AM   #15
arturo55's Avatar
Buts its more of a whining noise
Old 04-30-2013, 10:08 AM   #16
engines can make more noise on cold start up as all the oil leaks down and it takes a minute to lube it all up (mainly valve train noises) but who knows, could be injectors ticking due to being more rich (more flow) on cold engines. Could be something wrong as well~ Ford wont do anything until it breaks FYI
Old 04-30-2013, 11:06 AM   #17
Region: Nevada
You can do it for any 2011 to 2014. Look at your owners manual it will tell you how to do its it pretty easy. You can adjust your steering feel to sport, standard and comfort.
Old 04-30-2013, 08:30 PM   #18
BigClaunch's Avatar
Ok found it.
Old 04-30-2013, 10:32 PM   #19
Whitelightning's Avatar
Ok found it.
Where? I looked up and down. And I can't find it anywhere and was told it was only on GT. my premium doesn't have this.
Old 05-01-2013, 01:42 AM   #20
BigClaunch's Avatar
Oh I just pressed "set-up" to the left of the steering wheel until steering feel came up them press reset to scroll over.
Old 05-01-2013, 03:21 PM   #21
gorillaz131's Avatar
Ok so if its the same problem I had.. It's just the ac lines that a dripping water onto the belt.. That all.. U don't need a belt.. Try testing by driving with the ac on and leave the car off for awhile.. Ill probably notice the noise.. Then try another day with no ac on what so ever.. It should make the noise then
gorillaz131 is offline   Reply With Quote
Old 05-02-2013, 03:51 AM   #22
bucko's Avatar
This seems backwards....if it's the A/C condesnsor water that forms when the A/C is being used and dripping water on the belt(?), then it should make the noise when the A/C is on, right? No A/C would mean no water, and no noise?
Old 05-02-2013, 06:33 AM   #23
Ya this is what I've come to conclude into the theory and its seems about true cause this is what the mechanic told me at ford..
12:09 AM
