Tire Rub! - Mustang Evolution
Old 04-25-2013, 01:14 AM   #1
jaylee1202's Avatar
Tire Rub!
Hi, I have 2012 v6 mustang.
I just got lowering spring, which is eibach sportline.(they drop approximately Front 1.4in, Rear 1.7in)
After couple of days, I also got rims and tires which is GT brembo package.(tire size:255/40/19) However, when I turn my steering wheel all the way to right or left, the tire rubs inside. Therefore, I am considering to have 245/40/19. Anyone has idea if its okay with that. and would it still rub inside if I turn my steering wheel all the way?
Thank you guys!
jaylee1202 is offline   Reply With Quote
Old 04-25-2013, 01:23 AM   #2
The Puma's Avatar
Wheel spacers?
The Puma is offline   Reply With Quote
Old 04-25-2013, 01:25 AM   #3
jaylee1202's Avatar
yup.. I also considered wheel spacers... but a lot of my friends, who are mechanics didn't recommend to put wheel spacers on the front....
Old 04-25-2013, 01:26 AM   #4
The Puma's Avatar
Why is that?
Old 04-25-2013, 01:30 AM   #5
jaylee1202's Avatar
they said tires do not get tighten all the way into hub inside. so there is chance to tires can be fall off while Im driving... I don't want that risk...
Old 04-25-2013, 01:33 AM   #6
The Puma's Avatar
Wow... I've never heard of that. You'd think the drive wheels would fall off first, since they're always being torqued on and off. Maybe do some independent research on that one. I have some pretty big tires and never experienced any rub or anything, not even diminished turn radius...
Old 04-25-2013, 01:39 AM   #7
jaylee1202's Avatar
U also lowered your car? Springs or Coil overs?
Old 04-25-2013, 01:41 AM   #8
The Puma's Avatar
Springs. SR's. 1.5" front and back. My wheel wells sit right above the tire, maybe a quarter inch above. The front looks even lower than the back. It is pretty much in line with the wheel well.
Old 04-25-2013, 01:42 AM   #9
It's not me, it's you.
primer2tone's Avatar
I think the only problem you'd have with wheel spacers up front would be that you'd have to realign the front end.
Old 04-25-2013, 01:45 AM   #10
The Puma's Avatar
You have to do that on a slam anyways. I don't think spacers would need that, though. It evenly moves the wheels out. Not like a slam. That changes body position. I personally like my staggered set up and wouldn't want to push the tires out any further(plus its illegal in Europe). New tires would be pricey, though. Spacers would be a cheaper fix...
Old 04-25-2013, 01:47 AM   #11
jaylee1202's Avatar
what's your tire size? you have wheel spacers?
---------- Post added at 12:47 AM ---------- Previous post was at 12:46 AM ----------
But tires only have 10% thread... that's why I was considering that...
Old 04-25-2013, 01:52 AM   #12
The Puma's Avatar
I have no wheel spacers. Not personally a fan. I have 275/40/19 in the rear and 245/45/19 up front.
Well, if you almost need new tires anyway... **** it.
Old 04-25-2013, 01:54 AM   #13
jaylee1202's Avatar
Thanks Im thinking to get Hankook v12 evo.. those are fine? since I am almost broke.. I need sth cheap..
Old 04-25-2013, 01:58 AM   #14
The Puma's Avatar
Hankooks are always a reliable brand. They have mid range to ultra high performance. You always see Hankook sponsoring someone at shows and races.
12:16 AM
