Catbacks - Mustang Evolution
Old 04-25-2013, 01:08 PM   #1
Whitelightning's Avatar
Catbacks
Are the catback systems worth the bigger 1/4 bigger piping? Also if I do one, I can't switch out the axle backs I take it because they are straight clamped and not ball clamped like the stock. I'm looking at the magnaflow streets, their respective cat back and roush. Wanna eliminate the rasp and if possible not do headers for awhile.
Opinions on catbacks?
Old 04-25-2013, 02:19 PM   #2
The Puma's Avatar
Once you buy a catback of that size, your stuck. All axle backs for V6 will be stock size. In my opinion, upgrade to V8 2.75" and just buy GT axle backs after that. However, having a GT catback is too much volume and you'll see a decrease in HP due to a lack of back pressure.
---------- Post added at 09:19 PM ---------- Previous post was at 09:17 PM ----------
Never mind. Just saw you have a Boss. Worth the money. That engine will blow out hard. Don't waste your time or money with axles on a Boss.
The Puma is offline   Reply With Quote
Old 04-25-2013, 02:38 PM   #3
Charlie_santos's Avatar
He has a v6
Old 04-25-2013, 02:54 PM   #4
The Puma's Avatar
It says Boss on his profile...
Old 04-25-2013, 02:54 PM   #5
clamphier's Avatar
Boss look alike
clamphier is offline   Reply With Quote
Old 04-25-2013, 02:57 PM   #6
The Puma's Avatar
Oh. Okay. Makes sense enough. In that case, run FI before you step up over axle size... You really get nothing from it in V6. In fact, you lose power going so big.
Old 04-25-2013, 02:57 PM   #7
Originally Posted by clamphier View Post
Boss look alike
Boss 227 I believe from back in the day
Old 04-25-2013, 02:58 PM   #8
The Puma's Avatar
I have everything other than FI and I dyno better results with tune with stock over axles than 3" pipe.
Old 04-25-2013, 03:00 PM   #9
clamphier's Avatar
What do you dyno?
Old 04-25-2013, 03:05 PM   #10
clamphier's Avatar
Also what is a boss 227 I've never even heard of it?
Old 04-25-2013, 03:10 PM   #11
The boss 302 is the cubic in of the engine as our car is 227 he made his a boss 227. Its literally based on the cubic in of the engine. From what I understand
Old 04-25-2013, 03:12 PM   #12
clamphier's Avatar
Well that would make sense then. I was real confused I googled it and everything... should have put two and two together. He just said 227 replica so I had to make sure
Old 04-25-2013, 03:12 PM   #13
The Puma's Avatar
I don't know what a Boss 227 is, but a 227 is a V6 size engine. Maybe it was a joke? I dyno, RWHP 365 and 340TQ with tweaked hybrid tune. Best I ran was a 13.3. And that was against a POS Evo. (Can't help it, military. They own all types) and his 28psi turbo Evo 8 ran a 14somerhing.
Old 04-25-2013, 03:13 PM   #14
clamphier's Avatar
What all do you have done?
Old 04-25-2013, 03:13 PM   #15
The Puma's Avatar
But again, only ever dyno'd in Deutschland. They go off of something called KpW, not HP, I've been told its the same but who knows.
Old 04-25-2013, 03:14 PM   #16
clamphier's Avatar
That's a ridiculous number for bolt sons but could be right? Either way that's sweet
Old 04-25-2013, 03:22 PM   #17
The Puma's Avatar
Oh boy... Catback and over axle pipe2.50", with Pypes axle back, Airaid tune required CAI, Bama 'tweaked' hybrid tune, BBK throttle body, LCA's and PH bar, both JLT, GMax tires, 295 rear. 3.73 gears from Ford Racing. Borla LT's with shorty o/r x pipe, (I really want the one piece AL drive shaft!!) other than that, JLT catch can, bunch of MMD cosmetics (louvers, scoops and trim). Bunch of small stuff, and a few okay things. Ain't pushing nearly close to FI. Would if I had the money.
---------- Post added at 10:22 PM ---------- Previous post was at 10:20 PM ----------
Like I said, I may be wrong, I think it's the same, but DE does KpW... Their version of horsepower... May be less because euro trash sucks. I honestly have not gotten a clear answer. I'd love to just do it in the good ol USA and get an answer I like...
Old 04-25-2013, 03:22 PM   #18
clamphier's Avatar
I have all that plus the driveshaft but I got bbk headers and xpipe instead
Old 04-25-2013, 03:35 PM   #19
I got a custom drive shafts hit 500mph on a closed track... lol
Old 04-25-2013, 03:42 PM   #20
The Puma's Avatar
Lucky you Charlie! You aftermarket Demon! I'm cook with the AM one because it hits 8,600rpm with no failure or even smell. I don't plan on going that fast. Charlie, where'd you get yours?!
Old 04-25-2013, 03:43 PM   #21
Venomouz831's Avatar
Crazy you gained almost 100 hp from those mods
)02 Gt, Founder of WE2G
Old 04-25-2013, 03:43 PM   #22
clamphier's Avatar
I did driveshaft shop and I've taken it up to 155 with no problems..
Old 04-25-2013, 03:45 PM   #23
The Puma's Avatar
Hybrid tune is the biggest. I got a dude who does tune and he tweaked mine off if data logs. That's what his **** said, but all in German, and I've been told KpW is the same, least he did, and that's what it was.
Old 04-25-2013, 03:45 PM   #24
Well its not made here in el paso but I ordered it here. At a shop called car parts machine. $300
Old 04-25-2013, 03:47 PM   #25
The Puma's Avatar
Well , here iis a law in De, drive as fast as you want, but over 130k (78mph) and you're at fault. So I try not to...
Old 04-25-2013, 03:50 PM   #26
clamphier's Avatar
I was at tx2k racing a corvette I had to lol
Old 04-25-2013, 04:04 PM   #27
He is making a boss "clone" out of his V6, the 227 is the V6 engine so he named it the "Boss 227"
Old 04-25-2013, 04:09 PM   #28
clamphier's Avatar
Got it, makes sense
Old 04-25-2013, 07:30 PM   #29
It's 2.50 piping. Frees up like 10 or so hp vs. 1-3 on over axles. Just assuming
---------- Post added at 08:27 PM ---------- Previous post was at 08:26 PM ----------
It's 227 cubic inch motor. Much like the boss is a 5.0 or. 302 motor. My car is cloned after the patriot edition boss at Barrett Jackson.
---------- Post added at 08:30 PM ---------- Previous post was at 08:27 PM ----------
So I finally heard an H with the magnaflows. Ick.
So what can I run on mags to make them louder. And what about roush and the borla touring with headers. I know the roush cracks and pops from what Charlie has said and that one video on YouTube.
Old 04-25-2013, 07:46 PM   #30
powerwhee's Avatar
Borla
powerwhee is offline   Reply With Quote
Old 04-25-2013, 10:47 PM   #31
The Puma's Avatar
Intake manifold?
---------- Post added at 05:47 AM ---------- Previous post was at 05:46 AM ----------
I dyno'd with the stock 2.25 and 3.0 inch... All my German buddy had. He didn't have mustang pipe at the 2.75 inch stock.
Old 04-25-2013, 11:09 PM   #32
The Puma's Avatar
Also, if you think that's impressive, go on AM and watch their videos. They turn a few ponies into beasts with bolt on, and of course, eventually add FI, but before they do, they're running some bad *****es with just bolt on.
Old 04-25-2013, 11:17 PM   #33
Intake manifold?
What do you mean intake manifold? He is making his car look just like the patriot edition Boss, but it's a V6. Kind of plain and simple to understand (no offense intended at all, I just don't know how else to word it)
Old 04-25-2013, 11:21 PM   #34
The Puma's Avatar
Nah, it's fine. No offense taken. I think the confusion is, I have never heard of the patriot edition(which is bullsht because I eat, sleep ad breathe the Army!) (jk) But, more seriously... I was curious what intake manifold he has, because the Boss has the iconic '302' intake manifold. Or is this all just cosmetic conversion?
Old 04-26-2013, 12:02 AM   #35
I think cosmetic and hey bro how much did ur friend want to pay for the parts
07:26 PM
