are both of these necessary. they combined with install are kinda expensive. I was wondering if it would have the same effect of controlling wheel hop and wheel spin if I were to just get one or the other. which one is more effective? I am a newb when it comes to suspension.
If you wanna eliminate wheel hop go for the lower control arms. I believe they will reduce the most wheel hop. I've been looking into them also. Trying to lower my 60ft at the drag strip.
Only if your lowered you should need UCA mine lowered i have clunking noise in rear even after LCA and relocation bracket UCA is necessary for me and i still have wheel spin badd
Ask any real drag racer you eiether get both or neither. Save and get both at once. Ive been told that by guys racing 7 second drag cars. Ill listen to them.
PP is the GT suspension thats all lol beefier Front/rear sway bars and gt shocks n struts n shocks. Basically not that great of a upgrade besides u getting gears
I will say that the UCA is going to be a pain to butt to swap out later... You pretty much have to drop the rear end out of the car, or close to it. But if your doing LCA's then your half way there anyways... You can instal them both yourself with hand tools and some patience... My LCA's fought me for a while not wanting to go back into the new mounts but after some pushing and pulling and a little help from the jack I got everything back together.
Check out UPR. They make good stuff and they have great package deals... Look up Schrad. I think he lurks on this forum. If you can find him he can give you a discount code
so LCAs aren't hard to install for someone with no experience in suspension? I should go with eibach I guess? and I should just go with LCAs first and maybe UCAs later?
if you get uca get adj one and BMR is one of the best for suspension. Dont bother put gt parts or gt500 parts on if you want better handling go aftermarket there is a reason why those parts aren't on their car
I'm a fan of UPR myself. But BMR and some other companies also make good stuff...
I think you will be able to instal the LCA's yourself. It's not hard, just follow directions... What gets new guys on control arms is people don't realize that the rear axel can move forward and backwards in addition to up and down... I have gone to many people's houses to "help" them with something not lining up properly just to find that the rear axel shifted slightly forward... Simply fixed by growing some balls and giving the axel a few good tugs or whatever is needed.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
