headers - Mustang Evolution
Old 05-17-2013, 02:22 PM   #1
13 stang22's Avatar
headers
will long tube headers hurt my 0-60? people tell me that shorties will help my 0-60.
13 stang22 is offline   Reply With Quote
Old 05-20-2013, 05:57 AM   #2
bucko's Avatar
I disagree with the shorties. They are a good replacement for stock exhaust manifold replacement, but do not up the performance that much. Long tube is the best way to go, but will require some exhaust work to get them to connect to the stock pipes, unless you buy a complete kit.
Old 05-20-2013, 01:02 PM   #3
13 stang22's Avatar
I'm looking at decreasing my 0-60. I have 3.73 gears. tune. cai. throttle body. I do the 0-60 in 4.9 sec. could adding long tubes, x pipe, axle backs possibly get me down to 4.6 range?
Old 05-20-2013, 01:14 PM   #4
MidnightBlueGT's Avatar
With the tuner helping the lt's it wont hurt, it'll give about 30hp i believe.
Old 05-20-2013, 02:04 PM   #5
Charlie_santos's Avatar
Yes it could help bro but I would also buy LCA and UCA both Adj and it will lower ur 0-60 times
Old 05-20-2013, 02:33 PM   #6
13 stang22's Avatar
I'm having UCA and LCAs (both adj) installed on Thursday. should I expect any improvement besides better traction in the 0-60 from those? from what I understand shorties only help sound-no performance?
Old 05-20-2013, 02:35 PM   #7
Black on Boss's Avatar
Better traction = better 0-60
Old 05-20-2013, 04:15 PM   #8
13 stang22's Avatar
okay. if I get headers will that help me also? because I know torque is what gets you off the line and LT headers hurts torque
Old 05-20-2013, 05:30 PM   #9
The HP outweighs the loss in torque.
Old 05-20-2013, 05:45 PM   #10
13 stang22's Avatar
okay. I appreciate all the info
Old 05-20-2013, 11:31 PM   #11
alrefire's Avatar
get some wider rubber in the rear if you want a better 0-60
Old 05-21-2013, 08:03 PM   #12
NewMtang's Avatar
Since your not really getting a lot of gains from Shorty Headers, how about installing them to reduce the heat in your engine? For people who live in the desert areas like in Arizona or California?
Old 05-21-2013, 08:19 PM   #13
Whitelightning's Avatar
People keep forgetting the sound. Could care less of performance. Just want the sound.
Old 05-21-2013, 11:54 PM   #14
Adamp1's Avatar
Living in Cali leaves no choice for the shorty's. I want long tube headers but I don't want to change them back 5 years down the road. But if you get a catted x pipe with the long tubes will that make it carb exempt?
2012 V6 AUTOMATIC 3.7 / MAGNA FLOW MUFFLERS / 3.73 GEARS / STEEDA CAI / 91HYBRID OCTANE TUNE / STRUT BAR / GUNMETAL MATTE METALLIC RACING STRIPE / BBK SHORTY HEADERS / BBK 73MM THROTTLE BODY
Adamp1 is offline   Reply With Quote
Old 05-21-2013, 11:59 PM   #15
I dont think the high flow cats burn enough fuel as the stock cats for cali so I dont think you would pass unless you got different cats installed
Old 05-22-2013, 12:05 AM   #16
Adamp1's Avatar
That figures; I am going for power so I want long tubes and I am not moving to a different state because some hippie wants my car to run the same as their Prius. I will talk to my local muffler guy and see what he can do to get the pass on the visual.
Old 05-22-2013, 12:09 AM   #17
powerwhee's Avatar
You can just get the shorties and keep your stock midpipe. Maybe gut the oem cats? I'm in Cali to so I feel your lain
powerwhee is offline   Reply With Quote
Old 05-22-2013, 12:10 AM   #18
You could gut ur stock cats and have them welded into the off road pipe and have a tuner to clear the code right before you go to the inpection
Old 05-22-2013, 12:17 AM   #19
Adamp1's Avatar
When say clear the code do u mean check engine light?
---------- Post added at 11:17 PM ---------- Previous post was at 11:16 PM ----------
Are there any dyno results on the shorties? I haven't seen any for 3.7s
Old 05-22-2013, 12:18 AM   #20
Yea clear the rear o2 sensor code. So it will pass the test.
Old 05-22-2013, 12:25 AM   #21
Adamp1's Avatar
So will this code stay on until I need a smog, in my case, 5 years? Not sure i want that or would want to continuously clear the code.
Old 05-22-2013, 12:27 AM   #22
If you have a tuner it can be disabled permanently bro.
Old 05-22-2013, 12:30 AM   #23
Adamp1's Avatar
That's more like it, thanks, now I can get a quote on welding my cats on the off road pipe.
Old 05-22-2013, 10:23 AM   #24
13 stang22's Avatar
has anyone actually heard the shorties? are they that much different than the LTs in sound?
Old 05-22-2013, 10:49 AM   #25
Prolly not a difference really over stock headers
Old 05-22-2013, 04:02 PM   #26
13 stang22's Avatar
then what's the point of shorties? lmao
Old 05-22-2013, 04:09 PM   #27
Replacements for cracks stock ones or Eye Candy hahaha almost no gains and very minimal flow difference. Ford makes decent shorty headers stock the BBK ones arent that great why do u think u never seen any videos or any demos besides bbk themselves. I doubt many will buy them unless its for a show car or for replacements
Old 05-22-2013, 05:34 PM   #28
13 stang22's Avatar
I'm jus gonna get the LTs n call it a day
Old 05-22-2013, 05:38 PM   #29
Lmfao Idk why u didnt do that in the beginning bro!! They are THE way to go as for headers
Old 05-22-2013, 07:53 PM   #30
13 stang22's Avatar
haha I was jus curious
Old 05-22-2013, 07:55 PM   #31
Just paint your stock manifold, it'll give ya at least 5 HP
Old 05-22-2013, 08:39 PM   #32
I heard it gives u 12RWHP at -100RPM lol
Old 05-22-2013, 08:43 PM   #33
Im gettin mine done in Pink
Old 05-22-2013, 09:15 PM   #34
13 stang22's Avatar
I heard that if you put shorties on your 3.7 it will be faster than a new GT500. can't forget the cobra emblem either!
Old 05-22-2013, 09:20 PM   #35
01:12 AM
