spark plug wires - Mustang Evolution
Old 05-19-2013, 10:28 AM   #1
spark plug wires
I'm looking for a set of red spark plug wires for my 2011 V6. I haven't been able to locate them for a V6. Any suggestions
Thanks
wyzard is offline   Reply With Quote
Old 05-19-2013, 07:42 PM   #2
fordfan100's Avatar
Thanks
Doubt you'll find any since our cars have coil packs and everything is in a wiring harness. You could always get the pipe stuff that you put on them
fordfan100 is offline   Reply With Quote
Old 05-19-2013, 09:40 PM   #3
Charlie_santos's Avatar
Thanks
There isnt any bro. Buy the Accel Coil Packs
Old 05-20-2013, 05:41 AM   #4
bucko's Avatar
You have what is refered to as "COP's", which means "coil over plugs". No more spark plug wires. Over each plug, there's one of these COP's.
No reason to replace them with any other brand until they need replacement. The stock COP's are good enough for most any mod you do until you go the way of supercharhing your engine. The spark strength of the stock COP is plenty strong.
Old 05-20-2013, 01:42 PM   #5
No reason to replace them with any other brand until they need replacement. The stock COP's are good enough gor most any mod you do until you go the way of supercharhing your engine. The spark strength of the stock COP is plenty strong.
It really helps with the surging issue ppl have with there tunes.
Old 05-20-2013, 02:48 PM   #6
bucko's Avatar
OP did not mention anything in the way of mods (yet), but you have a valid point on an engine with a strong tune.
Lets see if the OP responds with any mods.
Old 11-27-2013, 12:10 PM   #7
Whitelightning's Avatar
Where are spark plugs located? Sorry I'm an old school guy. I know on a Chevy 350 or 454 they are low in the engine. Where are these? I'm using lots of gas for some reason and I need a tune up, I have 83,000 miles.
Old 11-27-2013, 02:28 PM   #8
U can easily see them on the driver side uts on the top of the motor. Look at the 3 circular objects held on with a single screw. It that off and unplug the coil pack and then u can take a spark plug socket and pull them out
Old 11-27-2013, 03:15 PM   #9
Ah so in the heads. That passenger side you gotta take the upper manifold off. Might as well clean my throttle body and manifold.
Old 11-27-2013, 04:29 PM   #10
I got mine port matched and I ported my TB myself
07:37 PM
