3.73 or 4.10? - Mustang Evolution
Old 05-23-2013, 07:00 PM   #1
FastFord13's Avatar
3.73 or 4.10?
I know its been discussed to death but I was planning to go 3.73 but now I'm considering 4.10 because top end rpm is not all that different than 3.73s according to AMs gear chart. Anyone who has done either set up have any input?
Old 05-23-2013, 07:04 PM   #2
Billymich's Avatar
I have 4.10s with a 5 speed, I like it for the most part but if I had a more powerful engine I would switch to 3.55's the 4.10s arent great on the highway due to higher revs and theyre mostly good in the city but it cause a bit of 'jerkiness' unless you're paying attention.
---------- Post added at 08:04 PM ---------- Previous post was at 08:03 PM ----------
If you have a auto or a v6 go with the 4.10's if you have a manual go with either 3.55's
Old 05-23-2013, 07:05 PM   #3
MidnightBlueGT's Avatar
373 are more for street usage and 410 are like drag strip gears. Both can be used but dont go 4.10s if thats your only mod or it will be a bumpy ride
---------- Post added at 09:05 PM ---------- Previous post was at 09:04 PM ----------
^ that too.
Forgot to mention tranny type
Old 05-23-2013, 07:22 PM   #4
FastFord13's Avatar
^ that too.
Sorry, manual.
Old 05-23-2013, 07:23 PM   #5
Originally Posted by FastFord13 View Post
Sorry, manual.
Not you lol i meant to mention which is best and forgot.
Old 05-23-2013, 07:41 PM   #6
FastFord13's Avatar
But the 4.10 s seem to pull alot harder.bit I wouldn't b a fan of the jerkyness though.
Old 05-23-2013, 07:43 PM   #7
What other mods do you have? Manual people still do 4.10's and love them. Occasionally some people complain that its jerky, usually those who are stock with 4.10's
Old 05-23-2013, 07:49 PM   #8
FastFord13's Avatar
Pretty much stock...roush axelbacks and will be tuning.
Old 05-23-2013, 09:10 PM   #9
4.10's are perfect but I have a 6 speed
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 05-23-2013, 09:23 PM   #10
Tomb1987's Avatar
Love my 3.55
2002 mustang gt
Future beast
Tomb1987 is offline   Reply With Quote
Old 05-24-2013, 04:25 AM   #11
FastFord13's Avatar
Is it a jerky ride?
Old 05-25-2013, 01:28 PM   #12
Billymich's Avatar
Look, I'm not trying to steer you away from the 4.10s, when I'm coming to a light in 2nd gear and it turns green or when I get on the highway, those are they only times I can really go full throttle otherwise I get wheelhop or I just spin my tires, I have 7in wheels all around on a fox platform, foxbody. I like the acceleration factor a lot I just might go with a less steep ratio if a genie asked me...
Old 06-05-2013, 03:37 PM   #13
Mustangs's Avatar
Our first gear ratio is super short (4.23) shorter than all these others guys transmissions. Putting 4.10s would make 1st almost useless. 3.55s or 3.73s are what you should go with. For daily street driving. There won't be much of a difference.
Mustangs is offline   Reply With Quote
Old 06-05-2013, 07:38 PM   #14
Bonnie12V6's Avatar
3.73's. you get 4.10's better buy a set of new rear tires with them.
Ryan
'Sally' 2014 Mustang GT 5.0, Black
Shelby GT500 Axleback, Res delete, Barton shift bracket.
United States Air Force
Bonnie12V6 is offline   Reply With Quote
Old 06-06-2013, 05:33 AM   #15
David Young's Avatar
I love my 3.73's but if Ford Racing had made 3.90 gears, i would have gone with them
David Young is offline   Reply With Quote
Old 06-07-2013, 01:39 AM   #16
Billymich's Avatar
Yeah, but what size are your tire/wheel combo cause mine are probably quite smaller, aka shorter overall ratio (esp with 4.10)
05:47 AM
