Intake causing drag? - Mustang Evolution
Old 05-26-2013, 08:12 PM   #1
NicholasP's Avatar
It seems as thought since the Cai install when I punch it down it doesn't shift as firmly and drags it seems to be holding me back. Before I could really get it reving and going but now when I punch it there's like a delay or something
NicholasP is offline   Reply With Quote
Old 05-26-2013, 08:14 PM   #2
Billymich's Avatar
Do you have an automatic>?
Old 05-26-2013, 08:16 PM   #3
2300turboford's Avatar
It may be the throttle by wire setup ^ maybe a tune will fix it but idk I'm sure someone will chime in and clarify
Old 05-26-2013, 08:19 PM   #4
Billymich's Avatar
If the CAI is all you have on the car, you may have lost some tq down low, but it should flow a tiny bit better up top. Remember one little mod won't change your car much it takes a bunch of complimentary mods to really do some damage
Old 05-26-2013, 08:54 PM   #5
Black on Boss's Avatar
I think Andy did somethin wrong
Old 05-26-2013, 09:39 PM   #6
NicholasP's Avatar
Yeah it's an automatic
Old 05-26-2013, 10:04 PM   #7
Adamp1's Avatar
What kind of intake did u put in? Was it a no tune required intake.
2012 V6 AUTOMATIC 3.7 / MAGNA FLOW MUFFLERS / 3.73 GEARS / STEEDA CAI / 91HYBRID OCTANE TUNE / STRUT BAR / GUNMETAL MATTE METALLIC RACING STRIPE / BBK SHORTY HEADERS / BBK 73MM THROTTLE BODY
Adamp1 is offline   Reply With Quote
Old 05-26-2013, 10:11 PM   #8
I could take a look at it tomorrow
Old 05-27-2013, 06:20 AM   #9
bucko's Avatar
What brand intake? My guess is you either forgot to install the tube that runs from the intake to the automatic, causing an unfiltered air leak that is messing with the MAF readings, or forgot to cap it, or that it requires a tune.
Old 05-28-2013, 08:28 AM   #10
Need to ask
Did you disconnect the battery while installing your CAI ??
I was told and it is in the Airaid instructions that it is an important step to disconnect the battery when putting the CAI on your car. I think it has something to do with the computer resetting for the increased air flow. I would guess this would cover all of the different CAI's
I put my Airaid on and hooked the battery back up and now I have way much better throttle response then before. When I floor the car it now has a great loud sound and I don't know if it accelerates better but it sure feels like it does. It shifts crisp and fast.
Try undoing your battery for about half hour or so and see if it helps.
I also hope you did not use oil or soap to put on the couplings to install them easier. If so you may have contaminated the MAF. I'm hoping not.
Old 05-28-2013, 10:53 AM   #11
powerwhee's Avatar
Did you do the idle re learn process?
powerwhee is offline   Reply With Quote
Old 05-28-2013, 01:28 PM   #12
No, I just had the battery disconnected
The first thing in the installation instructions was to disconnect the battery. I thought it was a strange request but did it anyway. I'm happy I did because I later found out it was to reset the computer for the increased air flow.
NicholasP should try disconnecting his battery for a half hour or so and see if that don't fix him up. It's free and may even solve the problem.
Old 05-28-2013, 03:15 PM   #13
Blogger
99ford's Avatar
^Try this^
I noticed that issue, and when I replaced my battery and did the idle re-learn problem solved
The directions were shady, no joke
(Just to clarify replacing the battery was not due in part of installing the CAI.)
Old 05-30-2013, 09:52 AM   #14
NicholasP's Avatar
Well since I got my oil changed it seems to be actually faster and more quick to respond than stock haha I guess they must have done something back to bookin it for me
Old 05-30-2013, 10:20 AM   #15
I would never pay someone to change my oil
Old 05-30-2013, 12:29 PM   #16
Blogger
99ford's Avatar
That's probably because they inflated your tires but they may have tightened it up as well did they remove the foam job?
Old 05-30-2013, 12:37 PM   #17
Blogger
99ford's Avatar
I do all the time because you only save about $5-10 on average. And right now the works is on sale for 29.99. You can't beat that.
Plus all the Ford dealers around here the 5th oil change is free so to me I just about break even. I'd never go to an express lube type place.
Old 05-30-2013, 08:33 PM   #18
But, I just can't trust anyone except me with my car. If I put the oil and filter on, I know it was done correctly. And who is to say these ppl put the correct oil in, and the correct amount of oil. I just don't trust strangers with MY car, just ain't gonna happen.
Old 05-30-2013, 09:47 PM   #19
Blogger
99ford's Avatar
Fair enough you got me there. I do watch them closely at Ford
Old 05-30-2013, 09:52 PM   #20
Lol, to each his own. Speaking of which, its about time for a oil change.
Old 05-31-2013, 09:46 AM   #21
Blogger
99ford's Avatar
Same with mine I got a free one from Ford
01:02 PM
