Octane issues? - Mustang Evolution
Old 05-27-2013, 12:50 AM   #1
Adamp1's Avatar
Octane issues?
So I think the rattling I hear, when my auto shifts, has to do with my octane. has anybody else had this issue?
2012 V6 AUTOMATIC 3.7 / MAGNA FLOW MUFFLERS / 3.73 GEARS / STEEDA CAI / 91HYBRID OCTANE TUNE / STRUT BAR / GUNMETAL MATTE METALLIC RACING STRIPE / BBK SHORTY HEADERS / BBK 73MM THROTTLE BODY
Adamp1 is offline   Reply With Quote
Old 05-27-2013, 01:17 AM   #2
DaBluedude's Avatar
If it's pinging then it's possible if you are tuned. Try a premium name fuel and see if it goes away. My mach 1 had a little pinging before I backed off the timing a degree and ran it 2 points richer. Car runs healthy and happy now.
2003 Mach 1
Old 05-27-2013, 05:53 AM   #3
bucko's Avatar
Your car came from the factory to run on 87 octane. If it has no tune installed, and the noise is truly pinging, I'd get it checked out as to why its pinging. Adding a higher octane to prevent the ping is only a band aid fix.
Now if it has a tune installed, then the higher octane may be required by the tune for the aggressive timing the tune has installed. The stock tune only requires 87 octane.
Old 05-27-2013, 08:01 AM   #4
Adamp1's Avatar
I have a 91 hybrid race tune on my vehicle. I was running the 87 street but the noise was still there. I don't recall hearing that rattle until I tuned the the vehicle. Also, what do you mean blue about running two points richer. Do you mean putting on a 93 octane?
Old 05-28-2013, 12:07 AM   #5
DaBluedude's Avatar
No. If you have a 91 octane tune you Neeeed to run 91 octane. Sounds like your tunes may be off a bit. By 2 points richer I mean through the tuner you can tune to make it run slightly richer at WOT.
---------- Post added at 12:07 AM ---------- Previous post was at 12:07 AM ----------
Originally Posted by DaBluedude View Post
No. If you have a 91 octane tune you Neeeed to run 91 octane. Sounds like your tunes may be off a bit. By 2 points richer I mean through the tuner you can tune to make it run slightly richer at WOT. I think it may be percent.
2003 Mach 1
Old 06-05-2013, 12:22 AM   #6
Adamp1's Avatar
Bama is having me run the 87 performance tune with 91 octane fuel. I just changed the tune this afternoon and will give it some time.
10:06 AM
