Gear install? - Mustang Evolution
Old 05-28-2013, 11:50 PM   #1
NicholasP's Avatar
Gear install?
How hard is it to install gears?
NicholasP is offline   Reply With Quote
Old 05-29-2013, 12:17 AM   #2
JayStang718's Avatar
Unless you know exactly what your doing take it to a good shop.
JayStang718 is offline   Reply With Quote
Old 05-29-2013, 03:09 AM   #3
bucko's Avatar
The gears have to be "meshed", which requires shimming. If you've never done this before, it's best to pay someone that does this.
Plus, your speedometer will be offand so the PCM will need to be flashed, unless you have a tuner that performs this.
Old 05-29-2013, 06:22 AM   #4
David Young's Avatar
I've installed every mod i have, with no help from anyone except for two. I let the 'pros' do my stripes and my gears. Just saying.............................
David Young is offline   Reply With Quote
Old 05-29-2013, 06:23 AM   #5
alrefire's Avatar
I've had my gears sitting in my room for about 3 months. Haven't had time.. But I should now!
Old 05-29-2013, 07:45 AM   #6
Tyriqq's Avatar
So would it be best to put my car back to stock so they can flash my PCM for the new gears and then put my tune back on afterward. Is getting the PCM flash only something a certified Ford center can do?
Tyriqq is offline   Reply With Quote
Old 05-29-2013, 08:37 AM   #7
Jayday20's Avatar
If u have bama tunes u can just get them to write a new tune for your new gears. You may actually need to do this anyways if they flash ur computer and you load your old tune your speedo may be off.
Jayday20 is offline   Reply With Quote
Old 05-29-2013, 08:46 AM   #8
Tyriqq's Avatar
I understand that part and yes I have a BAMA tuner. At any point after getting the gears put on that I revert back to stock, I still want it to read correctly
Old 05-29-2013, 08:55 AM   #9
Jayday20's Avatar
Oh okay gotcha yeah I would go back to stock have it flashed then when the device saves your new stock tune you will be good to go.
Old 05-29-2013, 12:00 PM   #10
ak_stang's Avatar
Region: Alaska
Watch a video on YouTube and see what it takes. Also go to iihs.net/fsm to see the ford service manual
ak_stang is offline   Reply With Quote
05:28 PM
