Vibration from 90+ - Mustang Evolution
Old 06-10-2013, 08:27 AM   #1
Vibration from 90+
2013 v6 premium with pp anytime I go over 90 my car vibrates
Rahbarin is offline   Reply With Quote
Old 06-10-2013, 08:46 AM   #2
dobypaw3's Avatar
Your tires my needs balanced the faster you go the more a vibration will be felt.
dobypaw3 is offline   Reply With Quote
Old 06-10-2013, 08:51 AM   #3
It has 500 miles you think they are unbalanced from ford
Old 06-10-2013, 10:13 AM   #4
bucko's Avatar
Not sure if auto assembly lines do the actual balancing; my guess is that it's subcontracted out. The rims were most likely sent off to a large tire shop, balanced, then sent over to the assembly line. With literally hundreds of tires balanced a day, it's very possible a few do not get balanced perfectly.
Other vibrations in tires can be from a belt seperating in a tire, although this is usually felt at lower speeds. Another is a tire that's out of round; that's rare these days too, but could be the culprit.
Take it in, get the tires re-balanced.
Old 06-10-2013, 05:42 PM   #5
Adamp1's Avatar
My car shook too, but it was due to a break job. When the removed my tires they didn't put the weights back on the tires.
2012 V6 AUTOMATIC 3.7 / MAGNA FLOW MUFFLERS / 3.73 GEARS / STEEDA CAI / 91HYBRID OCTANE TUNE / STRUT BAR / GUNMETAL MATTE METALLIC RACING STRIPE / BBK SHORTY HEADERS / BBK 73MM THROTTLE BODY
Adamp1 is offline   Reply With Quote
Old 06-10-2013, 09:37 PM   #6
could it be the drive shaft or something cause its only when i hit 90 and over i talked to a performance shop and they said the eagle f1 super car tires have the metal band overlap and at high speeds it could cause that but im trying to see if it could be something else
Old 06-11-2013, 03:03 PM   #7
David Young's Avatar
I bet you just need to have your tires re-balanced.
David Young is offline   Reply With Quote
01:00 AM
