Airbag light staying on - Mustang Evolution
Old 06-11-2013, 02:44 PM   #1
fordfan100's Avatar
Has anyone had the airbag light on the dash stay lit. My stayed on today and I just dropped it off at the service dept under warranty
fordfan100 is offline   Reply With Quote
Old 06-11-2013, 03:43 PM   #2
bucko's Avatar
Do the Mustangs flash the code with the air bag dash light? My 2005 Ford F150 had a airbag failure; it would flash the dash light code, pause, then flash the second code. This can then be found in a table which would describe the fault. Here's one that I used to find the faulty hardware:
http://www.airbagsolutions.com/docs/codes/f/es.pdf
Since your mustang is under warranty, this is mute. Also found this:
Old 06-11-2013, 05:19 PM   #3
fordfan100's Avatar
I didn't see a code flash just the light stayed on will find out tomorrow what the dealer says
Old 06-11-2013, 06:41 PM   #4
ak_stang's Avatar
Region: Alaska
You didn't have stuff in your from seat did you, if it senses weight that isnt enough to be a human or a baby it turns off the airbag
ak_stang is offline   Reply With Quote
Old 06-11-2013, 07:35 PM   #5
fordfan100's Avatar
No it was not the passenger airbag light on the dome light
---------- Post added at 07:35 PM ---------- Previous post was at 07:35 PM ----------
Nothing in the seat either I will let you know what the dealer says when I find out
Old 06-12-2013, 12:27 PM   #6
fordfan100's Avatar
Just got off the phone with my dealer. Apparently the airbag in the steering wheel is defective so they are replacing it under warranty.
Old 06-12-2013, 12:31 PM   #7
Venomouz831's Avatar
Good!
)02 Gt, Founder of WE2G
12:13 PM
