Anyone running a radar detector - Mustang Evolution
Old 06-18-2013, 02:01 AM   #1
Have this same issue? Whenever I get out of my car and lock it, my radar remains on.. I know in my old truck, even though still plugged in, when I turned it off, it would cut power to the radar as well. Now with my mustang, I'm noticing it never turns off. This concerns me for a few reasons. That being that it may effect the battery life in the long run, and two, at night it's basically a magnet for thieves because the power light is always on. Of course I could just unplug it every time I leave the car, but then I feel I might eventually damage the port or an actual part of the adapter. I suppose I could just turn the radar off before I get out, but it's difficult to remember. Is there anyway to get everything to power off when I turn the car off? Thanks.
Dhawk1313 is offline   Reply With Quote
Old 06-18-2013, 03:33 AM   #2
audioAl's Avatar
What brand is it, more info.
2014 DIB 3.7 "Blue Cyclone" /Sold
2016 ruby red GT 300 A with 3.55:1 gear/SVE resonator delete X-pipe/ UPR catch can/Airaid/AEM/Steeda/ BMR CB005/BMR CB006 brace/BMR cc plates/SVE springs/
Old 06-18-2013, 05:57 AM   #3
I don't know why but the port stays on.
This is the very first car I have ever owned that the accessory plug on the dash will not disengage the power when the key is turned off. I have the same problem with my Garmin GPS. I don't know what Ford was thinking when the idiot designed this very important item. I can think of no apparent reason for this to stay active when the key is turned to "OFF"
I can turn off my GPS manually but when it is plugged in it goes automatically into Charge Mode. I'm lucky to have kept my old Garmin 350 with the quick release mounting bracket to easily remove it when I park my car.
Is there any way you can manually turn off your radar detector ?
Old 06-18-2013, 07:55 AM   #4
Whitelightning's Avatar
My escort has a power cord now (original cordless) and when I shut it off the power cord will still have power but it kills it to the radar. Cordless will shut off after 20 minutes.
Old 06-18-2013, 10:44 AM   #5
F4nG's Avatar
i tapped in to the fuse box on the passenger side and just tucked the wires along a pillar and above the windshield
F4nG is offline   Reply With Quote
Old 06-18-2013, 11:05 AM   #6
tan
tan's Avatar
The power will remain in the cigarette plug after you turn off the car, at least for my '13. I'm not sure if it will turn off eventually or no. I wouldn't jeopardize the battery though.
tan is offline   Reply With Quote
Old 06-18-2013, 11:18 AM   #7
I have a Valentine one and their plug in adaptor was crap but they send u a harness to wire it directly into your fuse box, so thats what I did but I like the fact that it stays on even tho its is a pita to remember to shut it down
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
10:54 PM
