Tach/Speedo placement - Mustang Evolution
Old 06-27-2013, 09:07 PM   #1
Region: Iowa
Anyone else not like the placement of the tach and speedometer on their '12 Mustang? I would prefer the speedometer on the right for easier sight. Is there an easy way to change the positions?
ljoiner is offline   Reply With Quote
Old 06-28-2013, 06:32 AM   #2
easy fix
insert key ( do not start car)
hold in reset
Start car ( still holding in reset button)
test will come up ( let go of reset button)
Now just press reset to scroll to SPEEDOMETER
Now you have a nice easy to see digital speedometer.
The only problem is you will have to do this every time you start your car.
as far as putting the speedometer on the right and tach on the left. I don't know but I'm pretty sure it would not be cheap if it could be done at all.
Old 06-28-2013, 06:56 AM   #3
Region: Iowa
thank you... sounds like I need to try this... yes, I think actually physically changing positions will be very difficult...
Old 06-29-2013, 03:39 PM   #4
ArtU's Avatar
I have a 2013, from reading a few of these posts about a Speedo readout, I can't find a reset or a way to get Speed on the 2013 computer screen in the center between the large RPM and Speedo gauges.
Escort 9500ix Blue solved that for me, it reads out my GPS speed.
Old 06-29-2013, 04:09 PM   #5
BlackedStang's Avatar
There is a video on YouTube...somewhere...explaining how to do it on a '13. Lemme see if I can find it for you...
Here it is :
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 06-29-2013, 05:19 PM   #6
ArtU's Avatar
Here it is :
Thanks, that engineering mode looks like it reads out lots of the PIDs.
Old 06-30-2013, 02:57 PM   #7
Region: Iowa
I have a '12, not a '13, and I don't have digital dash, so this does not help.. question was to move actual speedo to the left in dash pod and put tach on the right.. has anyone done this? Is it possible?
Old 07-01-2013, 09:57 AM   #8
bucko's Avatar
Not easily, as the two guages are connected to the printed wiring circuit board within the dash cluster assembly. It would require some serious rearrangement of the printed circuit board to make this work.
But to answer your question, anything is possible. How good are you at modifying a printed wiring circuit board, or do you know someone that can do this for you?
Old 07-01-2013, 11:09 AM   #9
He can always just put it upside down.
Just Joking,
Bucko is probably 100% correct again. Everything is computer controled and uses printed circut boards.
I'm guessing that ljoiner will just have to live with the way Ford designed the instruments.
Old 07-02-2013, 09:55 PM   #10
Region: Iowa
@ronnie948
I think you are correct... will just have to live with it... oh well, other than that, the car is great!
Old 07-03-2013, 06:06 AM   #11
Don't Worry
You will get used to it.
Old 07-03-2013, 06:09 AM   #12
bucko's Avatar
I gotta say, I rarely ever look down at my tach with the automatic trans I have. I listen to the engines RPM's, so a tach is simply a visual aid.
Old 07-03-2013, 05:11 PM   #13
Midnight2012's Avatar
I never needed a tach with a manual.
Midnight2012 is offline   Reply With Quote
Old 07-04-2013, 07:01 AM   #14
bucko's Avatar
Another thought could be an external guage, such as a "SCANGUAGE" that plugs into the OBDII portits many outputs it can provide is a digital tach.
It provides a bunch more, including reading and clearing check engine type messages.
03:31 PM
