Manual transmission - Mustang Evolution
Old 07-02-2013, 07:24 PM   #1
arturo55's Avatar
Manual transmission
What can I do make this Transmission last
Build Rebuild Upgrade internal what can I do?
arturo55 is offline   Reply With Quote
Old 07-02-2013, 07:30 PM   #2
Black on Boss's Avatar
Drive it like you paid for it vs like you stole it. Hope that helped.
Old 07-02-2013, 08:56 PM   #3
tgmeyer's Avatar
Barton 2-post Shifter Bracket. Or even if you want more, get the whole short shifter conversion. Problem eliminated. Both can be found on AmericanMuscle.com
tgmeyer is offline   Reply With Quote
Old 07-02-2013, 09:03 PM   #4
No lol , don't waste your money on a Barton. Get a MGW and you will never regret it.
If you buy a Barton, you will always wish you spent the extra for a good shifter.
Old 07-02-2013, 09:32 PM   #5
+1000 look at the threads on here, read what people are saying, screw the barton, go with the mgw, its no comparison, and change tranny fluid to royal purple or amsoil, redline....those to things will make shifting fun again......
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
07:19 AM
