1st Plasti Dip Attempt! - Mustang Evolution
Old 07-12-2013, 03:35 PM   #1
RocknCali's Avatar
Ok guys you've inspired me NOT to play Call of Duty of my off day and be productive.
I've seen a lot you guys talk about plasti dipping.
So I'm gunna do my hood today and I'll have some updates along the way.
Here's a prep photo.
RocknCali is offline   Reply With Quote
Old 07-12-2013, 03:35 PM   #2
I want to see!!!
Old 07-12-2013, 03:36 PM   #3
Oh2freshstang's Avatar
Here I thought ur profile pic was ur car! Lmao. Good luck man it's super easy. Just make sure to take the tape of quick while the dip is still wet!
Old 07-12-2013, 03:54 PM   #4
RocknCali's Avatar
Take the tape off quickly? so it doesn't tear I assume. thanks for the heads up...
Here's after 2 layers...
ID:	117956   Click image for larger version
Old 07-12-2013, 04:07 PM   #5
Looks good! Are u re-taping after every layer?? U have to pull the tape off every time ur gonna let it dry or the dip will stick to the tape & when u go to take the tape off it'll peel the dip. I learned that the hard way!
Old 07-12-2013, 04:09 PM   #6
RocknCali's Avatar
haha really? I guess I'll learn the hard way too ....
I was bored and figured I'd try something new. plus it isn't permanent which is nice
Old 07-12-2013, 04:15 PM   #7
Yea that's the awesome part of plasti dip!! Haha.
Since ur doing a big piece of the hood I would suggest u lay all the dip down at once in layers & then take the tape of quickly! It's hard b/c u might get drips if ur not careful! The other option would be to put a later down..peel it..re-tape it..then repeat!
Old 07-12-2013, 04:43 PM   #8
RocknCali's Avatar
Haha well it's finished. you guys were right. after 4 layers and not retaking the edges were messed up but it looks good!
should I completely redo it or just retake and touch up the edges??
ID:	117968   Click image for larger version
Old 07-12-2013, 04:48 PM   #9
Same thing that happened to me the 1st I plasti dipped! & my smart a$$ did it twice because I didn't know what I did wrong! Haha. I would redo it because the edges are gonna stay up like that & it'll eventually start to peel! The best ways to do it are the 2 methods I said above!
Old 07-12-2013, 05:47 PM   #10
2010BlkMustang's Avatar
I like it! But yeah I agree, I think you should redo it, retaping it every layer. What part of Oceanside are you from?
2010BlkMustang is offline   Reply With Quote
Old 07-12-2013, 05:51 PM   #11
RocknCali's Avatar
I live off Oceanside blvd and pacific street
Old 07-12-2013, 05:53 PM   #12
Oh nice dude, that's pretty close! I live right off of Douglas and North river road.
Old 07-12-2013, 06:01 PM   #13
Adogg's Avatar
Another way you could have done it was take a razor blade and separate the plasti dip on the tape from the dip on the car did that for my bumper and it worked fine.
Don't hate....... appreciate
Old 07-12-2013, 06:07 PM   #14
1lowGT's Avatar
+1 that's what I did.
Old 07-12-2013, 06:29 PM   #15
RocknCali's Avatar
how do you get a nice smooth surface with it? mine was kinda blotchy
---------- Post added at 05:28 PM ---------- Previous post was at 05:27 PM ----------
how did you do that without scratching the paint?
---------- Post added at 05:29 PM ---------- Previous post was at 05:28 PM ----------
and if you did it that way what did you do with the overlap?
Old 07-13-2013, 11:35 AM   #16
1lowGT's Avatar
I had the tape there so i put a razor blade flat with the dip and peeled the tape you dont actually run the sharp edge down the tape you just put it flat so when you pull the tape the dip dont pull up. ANd i put newspaper over everything else for no over spray.
Old 07-13-2013, 11:43 AM   #17
Adogg's Avatar
^^exactly don't put the point of the razor towards the car just let the razor cut the dip as it is coming up
Old 07-13-2013, 12:22 PM   #18
RocknCali's Avatar
got it! I'll def try again
Old 07-13-2013, 12:36 PM   #19
DWC_SmOziLLa's Avatar
Another trick is to remove the tape while the plastidip is wet and then retape it once it drys to the touch for your next coat. Continue to do that as many times as necessary. Large flat areas are a pain to get a nice even coat with the rattle can. You can get a sheet of matte black vinyl for pretty cheap. It'd look alot cleaner. Good luck!
Old 07-13-2013, 01:08 PM   #20
Whitelightning's Avatar
Lol copy cat :p
Old 07-13-2013, 01:09 PM   #21
Will electrical tape or painter tape work? I just see it as ripping it up, dry that is
Old 07-13-2013, 01:12 PM   #22
1lowGT's Avatar
I would use painters tape. And i never tried removing the tape while it was wet
Old 07-13-2013, 01:14 PM   #23
1lowGT's Avatar
Dipped my lights and nose
Old 07-14-2013, 03:55 PM   #24
dobypaw3's Avatar
Use frog tape. It's the same as the blue (just a green color) painters tape but has a compound in it to keep the paint etc. from sticking to it. Google it.
dobypaw3 is offline   Reply With Quote
Old 07-14-2013, 05:57 PM   #25
Does it work with plasti dip tho?? I know it's meant for paint but plasti dip is a little different than pain I think. I actually just bought some but haven't tested it out.
Old 07-15-2013, 11:58 AM   #26
dobypaw3's Avatar
Test it on something before your car.
Old 07-15-2013, 12:56 PM   #27
I am I just thought u knew forsure!
Old 07-15-2013, 01:13 PM   #28
Bigkat122's Avatar
I did my decklid panel and gas cap today. Had the same issue with it sticking to the tape, but just on the very last bit I pulled off. It's barely noticeable from 3ft away.
Bigkat122 is offline   Reply With Quote
Old 07-15-2013, 01:25 PM   #29
Next time peel the tape off as soon as ur done spraying to get a nice line but it looks good!!!
Old 07-15-2013, 02:07 PM   #30
cariacou's Avatar
Attachment 118450
Attachment 118451
Attachment 118452
nicely done. I did the cap too but had a heck of a hard time clearing the pony.
best advice for plasti dip, pull while it's wet.
if you're not sure if it's still wet, spray an extra coat on the edges so you make the part close to the tape wet again.
2011 v6 convertible | Auto | Premium | Red Candy
* Selling *
Borla Atak v6 11-14 - 500/550$
Mustang Brembo Center Caps x4 - 50/60$
10-14 GT Faux Gas Cap - 30/40$
Premium Steering Wheel 11-14 - 100/150$
cariacou is offline   Reply With Quote
Old 07-15-2013, 05:02 PM   #31
Bigkat122's Avatar
I actually pulled it off and did another take. Just because I could. Sprayed a little closer to the car for less texture and pulled the tape off while wet. Heck of a difference!
Old 07-15-2013, 05:03 PM   #32
Sounds good! Yea it makes a difference pulling the tape when wet. I had to learn the hard way too! Haha.
Old 07-15-2013, 05:08 PM   #33
Bigkat122's Avatar
I was having so much fun I couldn't stop haha. So I did the chrome piece around the shifter knob too.
Old 07-15-2013, 05:42 PM   #34
Looks good! I wanna do all the chrome in the interior but I've been lazy! Haha.
02:39 PM
