What the heck is this? - Mustang Evolution
Old 07-16-2013, 07:41 PM   #1
NicholasP's Avatar
NicholasP is offline   Reply With Quote
Old 07-16-2013, 07:42 PM   #2
acornsmoke's Avatar
Originally Posted by NicholasP View Post
piece of rubber?
acornsmoke is offline   Reply With Quote
Old 07-16-2013, 07:43 PM   #3
Tyoung68's Avatar
Its a sensor to know if your hood is shut
Old 07-16-2013, 07:44 PM   #4
NicholasP's Avatar
What's it for I put it in drive and moved with it up
Old 07-16-2013, 07:45 PM   #5
Gera8712's Avatar
You have aftermarket alarm?
Gera8712 is offline   Reply With Quote
Old 07-16-2013, 07:49 PM   #6
Tyoung68's Avatar
Do you have a light under your hood?
Old 07-16-2013, 07:50 PM   #7
Region: New Mexico
Factory alarm.
Six7One is offline   Reply With Quote
Old 07-16-2013, 07:51 PM   #8
emery2483's Avatar
it might be so your hood doesn't slam so hard shut?
emery2483 is offline   Reply With Quote
Old 07-16-2013, 07:51 PM   #9
NewMtang's Avatar
It's a thingamjig. On the left side you have a V6, if on the right you have a GT.
Old 07-16-2013, 08:32 PM   #10
ak_stang's Avatar
Region: Alaska
Auto start maybe, so you don't accidently start you car with someones hands in there and standing in front of the car
ak_stang is offline   Reply With Quote
Old 07-17-2013, 04:29 AM   #11
David Young's Avatar
I think thats what it is too. I have the rubber sensor and i also have remote start.
David Young is offline   Reply With Quote
Old 07-17-2013, 04:34 AM   #12
bucko's Avatar
I'll take it you bought the car with it already installed(?)....
Follow its wiring back to the source. That should help you identify what its there for. If you have a remote start, then the previous explainations make sense.
Old 07-17-2013, 05:01 AM   #13
JimC's Avatar
That is the hood sensor for the factory alarm system.
If you ever have a problem with the alarm going off randomly, that is the sensor that usually needs replacing. It is most exposed to weather and it will read as the hood being open and trip the alarm. Had to replace it on my 2006.
It has nothing to do with remote start, easing the hood close, or any of the other guesses. I know what it is since I had to replace it. And if you look at a Mustang that doesn't have the factory alarm that sensor is missing.
JimC is offline   Reply With Quote
Old 07-17-2013, 05:41 AM   #14
Maybe so. I have it and its the only sensor i can see for the hood and my remote start won't work if the hood isn't closed. It might be used for the factory alarm and a safety switch for the remote start? Maybe?
Old 07-17-2013, 08:03 AM   #15
pwrby4d's Avatar
Sensor for Hood is correct. Factory Alarm.
pwrby4d is offline   Reply With Quote
Old 07-17-2013, 09:35 AM   #16
bucko's Avatar
Perhaps the remote start that was added to your Mustang uses the now identified factory alarm hood sensor? Did Ford install this remote start system? If so, they most likely knew about your factory alarm setup, and used the switch already there to trigger the disable of the remote start.
Old 07-17-2013, 03:29 PM   #17
Yes, its a factory remote start.
Old 07-19-2013, 06:23 AM   #18
It is the hood sensor for the factory alarm. I have a 'mercury switch' on the bottom of the hood which disables my factory remote start when the hood is up. On my wifes 2013 Ford Edge the factory alarm hood sensor is now used to also disable her factory remote start. Just to clear things up.........
Old 07-19-2013, 10:06 AM   #19
looks like an alarm
ErikMustang is offline   Reply With Quote
12:28 PM
