Changing radio - Mustang Evolution
Old 07-19-2013, 06:40 AM   #1
TruTalent94's Avatar
Changing radio
Recently I got the 2013 v6 mustang as my first brand new car and I love everything except the radio! It's the base model nothing special and I wanna replace the entire system and add a sub. But I wanna do it in pieces since the overall cost is 1500 for the set up I wanna have, the question is is there a cheaper route to go and could I hook up new speakers and an amp without replacing the radio yet. Anyone have any really good products they like and I'm looking to get a double din head unit any recommendations?
TruTalent94 is offline   Reply With Quote
Old 07-19-2013, 07:23 AM   #2
as far as putting a subwoofer on the stock radio this is something like what youll need
Xscorpion LC08A High to Low Line Output Converter w/ Gain Control
now for the double din I cant speak. I wanna say you have to change that whole face plate to put a double din in those newer cars but I have no clue!!
Old 07-19-2013, 10:57 AM   #3
2013's Avatar
I went with the sub first I put two 10in Memphis subs to my factory radio because the kit for a double din it's 200-300$
2013 is offline   Reply With Quote
Old 07-19-2013, 11:36 AM   #4
silvrbullet2012's Avatar
I put a single 10" DD 500 series in mine hooked up to the factory radio. Still need to change my door and rear speakers. Cost me 50 bucks to install here.
I rather keep the stock radio cuz of someone walks by and sees an aftermarket radio they might break in. Call me paranoid but it's happened before on other cars I've had.
silvrbullet2012 is offline   Reply With Quote
Old 07-19-2013, 11:53 AM   #5
Not paranoid I feel the same way. I just have never hooked up subs to a stock radio. It must need a power booster or amp to be able to push out the proper power
Old 07-19-2013, 05:00 PM   #6
dobypaw3's Avatar
I haven't bought an after market sub in 10 years, but the last one i did, i bought and hooked it up to my stock radio. Google: Bazooka base tubes. You can get them in 6", 8", and 10" each one puts out base deeper than they are. The best part when you connect a powered Bazooka tube it takes a power and ground wire then you connect it directly to your factory speakers from way if low input. As soon as they detect harmonics they power up. The best part you can connect a non powered tube threw the output of the powered tube and you will have two 10" tubes that will shake the s**t out of your car. It will be like have two 12's except they take up a lot less space.
dobypaw3 is offline   Reply With Quote
Old 07-19-2013, 08:29 PM   #7
curtin1991's Avatar
Send a message via ICQ to curtin1991
I used a line input converter and I'm running a 15 in fozgate p3 with a 1000w Memphis amp it's really loud . Sounds good for a stock radio . Cost me about 15 off eBay
Corey
curtin1991 is offline   Reply With Quote
Old 07-20-2013, 05:42 AM   #8
Thrundawg's Avatar
We're do you install the converter at?
Thrundawg is offline   Reply With Quote
Old 07-20-2013, 06:01 AM   #9
I would replaced the factory speakers first. They sound terribly flat. I replaced mine last weekend and sound so much better, I'll put off a head unit replacement. I do not listen at thundering volume though, and a sub would be a bonus, but I'll get by. Get those done first. Biggest improvement with the least amount of cash.
lcseds is offline   Reply With Quote
Old 07-20-2013, 09:57 AM   #10
curtin1991's Avatar
I actually learned about it from this site but it simply splices into one of your factory speaker wires .on one side and the other side has RCA out puts . I used the back speakers since its closest to my amp.
The way I listen to mine is adjust the bass of the radio how I like it and then adjust the bass knob to the amount you prefer .
Corey
Old 07-20-2013, 11:07 AM   #11
Thrundawg's Avatar
So I need two converters? One for each rear speaker?
Old 07-20-2013, 01:16 PM   #12
curtin1991's Avatar
No sir . Just one assuming you are only one amp for both subs
Corey
Old 07-20-2013, 01:38 PM   #13
curtin1991's Avatar
This is like the one I use works great
ID:	119516   Click image for larger version
Corey
Old 07-20-2013, 02:04 PM   #14
dobypaw3's Avatar
Just save some money and get a 10" Bazooka bass tube. No converter needed. Hook up your power and ground the run wires from the stock or existing speakers into the input on the powered bass tube . And you are done. Much cheaper than a sub, box, converter and separate amp.
Old 07-20-2013, 02:15 PM   #15
curtin1991's Avatar
Lol not sure where the glas of milk come from but it won't come off
Corey
Old 07-20-2013, 03:29 PM   #16
dobypaw3's Avatar
Good things it's just a picture of a glass of milk. Could have been real embarrassing for you!!!
Old 07-20-2013, 03:33 PM   #17
curtin1991's Avatar
You could hook up any sub to the factory speaker wires it's just not going to have much power pushing it. I know my sub wouldn't hit much at all
Corey
Old 07-20-2013, 04:08 PM   #18
curtin1991's Avatar
That is so true ! Lmao
Corey
Old 07-20-2013, 04:14 PM   #19
dobypaw3's Avatar
That's why you hook up a powered sub to your speakers. A sub with out it's own power is useless.
Old 07-20-2013, 09:18 PM   #20
curtin1991's Avatar
Ok I didn't realize the bazooka tube had an amp. My bad man
Corey
Old 07-22-2013, 02:04 PM   #21
dobypaw3's Avatar
You can buy a powered Bazooka and a non powered Bazooka tube. You can also hook a non powered to a powered Bazooka for double the base.
Old 07-22-2013, 03:01 PM   #22
ToHellAndBack's Avatar
I wana get one of the NOS bottle bazooka tubes
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 07-22-2013, 03:20 PM   #23
dobypaw3's Avatar
That would be cool. get two and mount them side by side.
10:44 PM
