Should i race in drive or S? - Mustang Evolution
Old 07-19-2013, 10:47 AM   #1
2013's Avatar
Does it matter? which is faster?
2013 is offline   Reply With Quote
Old 07-19-2013, 12:48 PM   #2
SouthernCyclone's Avatar
Sport mode locks out 6th gear, changes torque convertor settings. I drive my car in Sport mode but I don't use the + or -. I just put it in Sport mode and let the computer shift it out. Yes its faster then drive. All that should be in your factory book.
SouthernCyclone is offline   Reply With Quote
Old 07-19-2013, 12:50 PM   #3
2013's Avatar
Originally Posted by SouthernCyclone View Post
Sport mode locks out 6th gear, holds each gear higher before shifting. All that should be in your factory book.
So which do you think is better
Old 07-19-2013, 12:55 PM   #4
For racing, sport mode with the computer shifting it out.
Around town I keep it in drive.
Ride in Sport mode, then shift it up to Drive and you will see the rpms will drop about 200 rpms as soon as you shift into drive from sport mode. Higher rpms means your in the power band faster more often.
Old 07-19-2013, 08:27 PM   #5
elliottxspyder's Avatar
is it bad to have the computer automatically shift it in sport mode? I always thought it was only meant to manually shift using +/-
2013 Candy Red Metallic PP V6 - Airaid CAI - Roush Axle Back - 20% tint all around - GT Grille with MMD fog Delete
elliottxspyder is offline   Reply With Quote
Old 07-19-2013, 09:36 PM   #6
JimC's Avatar
Nothing bad about it at all, it is simply a factory "performance" tune for the automatic - and shifting manually with the +/- is just an option.
JimC is offline   Reply With Quote
Old 07-20-2013, 10:19 PM   #7
Oh2freshstang's Avatar
What about with a bama tune? Would it be better to race in D or S??
Old 07-21-2013, 10:07 AM   #8
clamphier's Avatar
I have a bama tune and always use s, roll up next to someone in d stop it to s and take off!
clamphier is offline   Reply With Quote
Old 07-21-2013, 12:23 PM   #9
At the track I always run it in S. I'm test out the difference between S & D next time!
Old 07-21-2013, 12:28 PM   #10
clamphier's Avatar
It was almost 2 tenths for me!
Old 07-21-2013, 12:36 PM   #11
So S was better for u? I figured I wanna see what difference I get!
Old 07-21-2013, 12:43 PM   #12
clamphier's Avatar
Yea that was with it in s mode
Old 07-21-2013, 03:54 PM   #13
Any progress on the turbo setup?? I'm still anxiously waiting!
Old 07-21-2013, 04:07 PM   #14
clamphier's Avatar
Doing it this week hopefully!
Old 07-21-2013, 04:25 PM   #15
Cool man ill keep my fingers crossed for u! Haha.
Old 07-21-2013, 04:41 PM   #16
clamphier's Avatar
Its gonna get done, and no reason it shouldn't work! Lol
Old 07-21-2013, 07:59 PM   #17
Haha. True!! I just wanna see the #s already!
Old 07-21-2013, 08:29 PM   #18
clamphier's Avatar
Soon enough don't worry!
Old 07-21-2013, 09:58 PM   #19
Region: New Mexico
Bama tune does not improve the Sport mide ( +\-) shift performance. All other tunes will still be in play though.
Six7One is offline   Reply With Quote
Old 07-21-2013, 10:21 PM   #20
clamphier's Avatar
It did for me?
Old 07-21-2013, 10:45 PM   #21
Awesome bro!
Old 07-22-2013, 12:21 AM   #22
13 stang22's Avatar
I'm lookin forward to this^
keep us all posted
13 stang22 is offline   Reply With Quote
Old 07-22-2013, 12:37 AM   #23
clamphier's Avatar
I will don't worry! Triple ball bearing and oiless should go good!
Old 07-23-2013, 12:42 PM   #24
So I just got this reply from bama!
Old 07-23-2013, 12:49 PM   #25
clamphier's Avatar
All the limiters and everything is off on mine in s
Old 07-23-2013, 12:54 PM   #26
Yea he said the limiters are all removed but I think the difference would be the shift points!
Old 07-23-2013, 12:59 PM   #27
clamphier's Avatar
Oh yea its ridiculous it hits the rev limiter and the down shifts are great too
Old 07-23-2013, 01:10 PM   #28
Yea I know I love sport mode!
Old 07-23-2013, 06:41 PM   #29
mrkrabz's Avatar
I don't think it locks out sixth. It changes shifting times (assuming you don't push + or - )it adjusts traction control, and puts the steering in sport mode.
I used to drive in S all the time, until I noticed that it uses a lot more gas. :/ But you do get a bit more power in S.
You should always race in S btw.
mrkrabz is offline   Reply With Quote
Old 07-23-2013, 07:47 PM   #30
Midnight2012's Avatar
I'm sure it does. Traction control and steering modes are independent of putting the trans in S.
And WOT holds the trans to redline in D or S
Midnight2012 is offline   Reply With Quote
Old 07-23-2013, 11:15 PM   #31
S mode doesn't change the steering! Only when u take traction control off it changes steering to street!
Old 07-23-2013, 11:28 PM   #32
mrkrabz's Avatar
Yeah, you're right. I was thinking of the sport setting for TC
Old 07-24-2013, 01:35 PM   #33
JimC's Avatar
It does lock out sixth. Try driving with the car in S and then when you are up above 45 mph shift it to D and it will shift up once more. If you continue to drive in S and get on the highway it will never shift up to 6.
Old 07-24-2013, 01:39 PM   #34
clamphier's Avatar
You can shift up to 6th in sport mode....
Old 07-24-2013, 01:41 PM   #35
JimC's Avatar
Yes you can manually shift up to 6th, but if you leave it in S and don't manually shift then 6th is locked out. Just like the OD button on the earlier models.
10:21 PM
