Car wont start... :-( - Mustang Evolution
Old 08-04-2013, 06:37 AM   #1
dgrum04's Avatar
Went to leave this morning in the Mustang, jump in, turn the key, click click click click, etc. is all I get. (Then the lights flashing and such)
I have electric so it can't be the battery, I'm leaning toward the starter right now? It's still under warranty so I'm not to worried, just upset that I'm going to be without my baby.
I'm not to familiar with warranty work. Does the dealer come pick the car up, or is it my responsibility to get a tow there?
2011 Kona Blue 3.7L. Stock motor. Roush Axle-Back. 19" x 8.5/10" Charcoal AMR's. GT500 Spoiler. Smoked Raxiom Tail Lights. MCA grille. Shorty antenna.
An outstanding DD
dgrum04 is offline   Reply With Quote
Old 08-04-2013, 07:01 AM   #2
Ubnbit's Avatar
It could still be battery brother. U might have had some charge, just not enough to crank it over. Did u leave the dome light on or something?
---------- Post added at 09:01 AM ---------- Previous post was at 09:00 AM ----------
If u call, they will come and get it or u could hook a new battery to it and try to crank it.
Old 08-04-2013, 07:08 AM   #3
Iggy's Avatar
I agree it still could be the battery mine did the same thing all my lights worked and I checked the battery and it was pulling the right volt amount to come to find out it had a bad cell in it.
Iggy is offline   Reply With Quote
Old 08-04-2013, 07:20 AM   #4
Iggy is probably correct on this.
A BAD CELL
If you jump it and it starts just drive to a place to get a new battery. ""NOT WALMART"" Their batteries are so bad they will only replace the first one that goes bad. The replacement will only go bad and you will have to buy another battery. Go to Autozone or Sears or if you have a membership go to Sam's club and get a Duracell. (((NOT THE SAME AS A WALMART BATTERY}}}
Old 08-04-2013, 07:24 AM   #5
David Young's Avatar
A BAD CELL
+1. Bad battery. Still has enough power for lights, radio etc. but not enough to start.
David Young is offline   Reply With Quote
Old 08-04-2013, 07:32 AM   #6
It's not me, it's you.
primer2tone's Avatar
If you've got a manual transmission, pop start that sucker!
After you replace your battery get the charging system tested. If you've been driving on a dead/weak cell, that puts extra strain on your alternator. If it's weak you'll wanna have that taken care of before it leaves you stranded again.
Old 08-04-2013, 08:26 AM   #7
dgrum04's Avatar
Thanks for the quick help, guys. I'm out for the day, but once I get back we're going to try and jump it tonight. I'll keep this thread updated with the progress.
Would it still be worth dropping (or having them come get it) it at the dealer Monday morning and having them look at it? I don't want the alternator to go next if this is going to continue...
An outstanding DD
Old 08-04-2013, 08:38 AM   #8
You probably don't have an alternator problem at all
It is pretty common for a battery to go bad but really having the alternator go bad is very VERY rare. Sears or Autozone can check to see if it's charging ( Usually free) when you get a battery from them. If your car is still under warranty and you have the Ford roadside assistance and want the Ford Motorcraft battery just go ahead and call them. I wouldn't worry to much about an alternator going bad due to a bad cell in the battery. The Alternators are pretty tough and do have protection from back-Shorts.
Old 08-04-2013, 08:42 AM   #9
Iggy's Avatar
Just for the heck of it pull your battery and take to like autozone or a shop the can put a load test on it. It won't cost anything your cars a 04 right well mine is 03 if its the original battery it might be going bad.
Old 08-04-2013, 08:48 AM   #10
Iggy's Avatar
I agree with Ronnie about the alternator I dout it's that or the starter let us know what you find out.
Old 08-04-2013, 09:05 AM   #11
dgrum04's Avatar
Just got a chance to jump it and it started no problem. I'm at sears now getting a new battery and hopefully that's the only issue.
An outstanding DD
Old 08-04-2013, 09:17 AM   #12
Iggy's Avatar
Let us know about that battery
Old 08-04-2013, 09:54 AM   #13
BlackSmoke02's Avatar
When you turn your key into ignition without it turning on and all the gauges flicker and cross all the way over from one end to the other and back down usually its a sign that its a problem with just the battery. Like said you could take it to Autozone but preferably O' Reilly or somewhere else because they test the battery and give you an exact note about it
BlackSmoke02 is offline   Reply With Quote
Old 08-04-2013, 09:58 AM   #14
He went to SEAR's
They will test the charging system as well as the Battery. They are famous for having excellent die-hard batteries and great warranty's on them.
Old 08-04-2013, 10:28 AM   #15
dgrum04's Avatar
Well, after Sears and Sam's not having the right battery, I ended up at Autozone for a Duralast. I have a good buddy that was working at the time I was there and he did a full test on my alternator and my battery and in fact, the battery was completely dead. (The alternator was good.) Anybody else have to replace a batter on a 2011+ model? Just seems really early to be replacing batteries...
Got the car home and replaced the battery, started right up. The car is going to sit until this evening, so when I get home I'll start it up again just to make sure it's good to go for tomorrow.
Thanks again for your help, guys. My initial diagnosis was wrong and I'm glad I have my ME community behind me!
An outstanding DD
Old 08-04-2013, 12:29 PM   #16
RocknCali's Avatar
A BAD CELL
Duracell is great but I ONLY USE Optima.
Yellow top Optima batteries are beautiful! not water filled they use a gel, and have something like a 3 year warranty but I'VE NEVER had to replace any of my red tops in my jeeps and F150.... spend the extra $40 for something that'll last..
RocknCali is offline   Reply With Quote
Old 08-04-2013, 02:01 PM   #17
Iggy's Avatar
I bought the battery love it pricey but well worth it.
Old 08-04-2013, 02:55 PM   #18
Siber Express's Avatar
Batteries are a Crap shoot, I have had OEM Batteries last for 200,000 in my 2000 Explorer and replaced the one in my 2002 Explorer at 34,000. And there really is no rhyme or reason why it fails.
Old 08-04-2013, 04:52 PM   #19
NewMtang's Avatar
CONFUSED....
I am a little confused. IF IT IS STILL UNDER WARRANTY, WHY DIDN'T YOU TAKE IT TO FORD AND LET THEM PUT IN A NEW ONE?
Old 08-04-2013, 04:57 PM   #20
Ntbruncie's Avatar
I had my battery in my 2012 replaced last month by ford. And it was covered by warranty 3 years 36 k miles it's covered
Ntbruncie is offline   Reply With Quote
Old 08-04-2013, 06:24 PM   #21
RocknCali's Avatar
LOL damn...
Old 08-04-2013, 06:46 PM   #22
If he still has the other battery he can throw it on and drive it to the dealer for replacement. Just make sure yoh make it Lol
Old 08-04-2013, 08:28 PM   #23
Ubnbit's Avatar
Def hope he didn't buy one yet lol. It should be covered.
Old 08-04-2013, 08:33 PM   #24
RocknCali's Avatar
he did
Old 08-05-2013, 04:03 AM   #25
bucko's Avatar
Two years on the stock battery was a bit early to go...Ford may have given you a credit, as they are 4 year batteries if my memory serves when they come from the factory.
My F150's stock battery gave up after 5 years...bought a Motorcraft battery to replace it because it lasted a year over it's advertised lifespan. The parts guy there said they (Ford), like most everyone else, will "pro-rate" a battery, meaning that if it fails before its advertised rated life, they give you credit on it. So, if you had a 4 year battery fail in two years, they give you 2 years worth of credit on the purchase of the replacement battery.
Too late for you now though!
Old 08-05-2013, 09:09 AM   #26
dgrum04's Avatar
I'm past the standard 36k warranty and into my extended warranty that will cover me to 80k(ish). Under the extended warranty, (this is from my dealer) the battery is not covered and they wont even do a credit like Bucko was saying.
An outstanding DD
03:01 AM
