Replace stock side mirrors with heated? - Mustang Evolution
Old 08-04-2013, 08:05 AM   #1
Have a 2013 V6, and want to trade out the existing side mirrors with heated/defrosting ones. Is this possible/easy/hard/impossible/inadvisable? How best to get replacement mirrors (Ford, eBay, junk yard, etc)?
Thanks!
Mike
Jennienmike is offline   Reply With Quote
Old 08-05-2013, 03:59 PM   #2
NewMtang's Avatar
Not wanting to bust your balls but it's beginning to look like you didn't do much planning when you bought your V6. You didn't get one with the nav unit and you don't like the mirrors because there not heated. You waited till after you purchased your car to ask if they can be put on after you bought it.
Old 08-05-2013, 04:16 PM   #3
Region: New Mexico
Yikes, who pissed in your cornflakes this morning? Sheesh.
To the OP: It seems that there is a distinction between non-heated and with heated mirrors for parts compatibility. Your parts counter may be able to help. If you are able to just put one on, they are about 200 each on eBay.
Six7One is offline   Reply With Quote
Old 08-05-2013, 04:23 PM   #4
FastFord13's Avatar
Lmfao! Wouldn't want to cut him off in traffic today. Lol
Old 08-05-2013, 04:28 PM   #5
Region: New Mexico
Nope!
Old 08-05-2013, 05:26 PM   #6
Wow. Thanks for your input. Perhaps I found a car, in the overall style I like, in a price range that I was looking for. Upon achieving that particular mission, I then chose to set out to ask on a fairly informative forum which niceties I may be able to add on afterwards. Perhaps I did make a horrible mistake when not considering these lacking options as deal-breakers.
Again, thank you so very much for your helpful advice.
Old 08-05-2013, 05:40 PM   #7
BlackedStang's Avatar
Don't pay attention to him. He is just an old man with nothing better to do but post smart a$$ remarks on threads
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 08-05-2013, 05:50 PM   #8
Region: New Mexico
Its the internet...it gives EVERYONE a "voice".
Good luck in your search.
Old 08-05-2013, 05:52 PM   #9
Very true. I just don't understand, why are you going to post a whole paragraph, while contributing nothing relevant to the thread?
Old 08-05-2013, 05:52 PM   #10
Region: New Mexico
Because they can. And nothing is at stake.
Old 08-05-2013, 07:58 PM   #11
Region: New Mexico
Lol
We knew what you meant.
Old 08-06-2013, 05:12 AM   #12
Kona Mike's Avatar
Funny, nobody ever complains that their auto transmission was made in China, or that the syncros are going, or that they have a bad smell coming from it, or that there shifter is rubbery and needs to be upgraded, or that it rattles, or they blew it up power shifting like an idiot. My shifter works well, and it works fast, and I got it for a bargain. 20k got me a loaded, like new 5.0 AUTO that's smoking fast!
Kona Mike is offline   Reply With Quote
Old 08-06-2013, 05:21 AM   #13
bucko's Avatar
Lets keep this thread on track please.
Back to the OP....you may also want to check that all Mustangs, or your model, is prewired for heated mirrors before you make the purchase. It seems logical that Ford would use one major wiring harness for all models, but it may not be the case. In the past, they did use different harnesses for different models that recieved options.
Old 10-31-2013, 06:39 PM   #14
joshuabowman's Avatar
So I also Have been looking into this as the Package was not on the Car I picked do to inventory availibe. So I pulled the cover on the drive side and it does have 7 wires running to the pig tail but my non heated mirror only has 4 pins. So I think I'm going to get an heated with pony projector mirror and try it out. I need to find a heated mirror button and location so i can see if there is a pig tail for the connection as well.
joshuabowman is offline   Reply With Quote
Old 11-01-2013, 05:53 AM   #15
bucko's Avatar
So there's a seperate button on the dash to operate the heated mirrors....the owners manual should show that.
Before I purchase the mirrors, I'd remove the blockoff plate (assuming you do not have this switch/push button) to see if that too is pre-wired.
Old 11-01-2013, 07:18 AM   #16
So after reading in the owners manual I found out that the headed mirrors are tied in with the rear defrost. Just need to find a donor car now.
Old 11-01-2013, 07:51 AM   #17
bucko's Avatar
Cool beans; that makes sense.
To the boneyards!
Old 02-04-2014, 10:52 AM   #18
Ok, bit the bullet and ordered the headed mirrors with pony light after testing the wiring on my car. If everything god well I'll have them on next week and I'll do a write up as well.
Old 02-04-2014, 11:58 AM   #19
Abominable Mustang
WhoDat's Avatar
Region: Alaska
How'd you test it? Just disconnected the side mirror connector and check for power with a multimeter while the rear defrost was on?
2012 Kona Blue 3.7L V6:
Old 02-04-2014, 12:02 PM   #20
I used a test light. Grounded it to the door and probed the #5 and #6 wires on the plug when I disconnected it and when I pushed the rear defrost and opened the door for the pony light they both worked. The one for the pony light faded when I locked the door as well just like the map lights.
Old 02-04-2014, 12:40 PM   #21
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Awesome. Looks like I'm gonna continue my search for a set of heated side mirrors haha
Sent from my HTC One X using Mustang Evolution mobile app
Old 02-05-2014, 02:45 PM   #22
Order the mirrors with your color
Kona Mike say's:
Kona Mike needs to know that the Manual transmission is made in China, The Automatic is made in Michigan U.S.A.
Both are very good transmissions.
Who Dat, Try to get a set painted the same color as your car.
Old 02-05-2014, 10:05 PM   #23
paintmann111's Avatar
keep us in the loop and if someone could do a write up, including a parts list, that would be awesome.
paintmann111 is offline   Reply With Quote
Old 02-07-2014, 03:04 AM   #24
bucko's Avatar
Since the mirror circuit uses the rear window defrost button, the only parts would be the mirrors themselves. They have a symbol imbossed in the glass to indicate they are heated.
So, I'd say the parts list is down to just the left/right power mirror:
2013 Drivers side power and heated - 2013 Ford Mustang Door Mirror | FordParts.com
2013 Passengers side power and heated - 2013 Ford Mustang Door Mirror | FordParts.com
I did not find a heated mirror available for the 2011 and 2012, so be careful; these years may not be pre-wired. I'd guess the 2013's would fit, but the heated mirror portion may not work.
Old 02-07-2014, 09:39 AM   #25
This is slightly off subject but I was wondering if the 13 mirrors would fit a 10-12. I have a 2010 that's missing the "blind spot" mirror was I was thinking about buying that and found a good deal on 13 mirrors.
Priestblack is offline   Reply With Quote
Old 02-07-2014, 11:41 AM   #26
Ok install write up to come in a few hours. All you need is the left and right mirrors, an 11mm wrench and a flat tip screwdriver. I now have pony lights and headed mirrors. Click image for larger version
Name:	ImageUploadedByMustang Evolution1391798479.738845.jpg
Old 02-07-2014, 11:56 AM   #27
Niceeee!!!
Old 02-07-2014, 01:40 PM   #28
Abominable Mustang
WhoDat's Avatar
Region: Alaska
I was noticing that too, but I'm proficient/confident enough with wiring that I could tap into the rear defrost wiring and retrofit my 2012 to work with 2013 heated mirrors. I've just gotta make sure the 2012 connectors have slots for the pins.
Old 02-07-2014, 02:49 PM   #29
Maggio's Avatar
Nice! Where did you order them from? how much did you pay?
Maggio is offline   Reply With Quote
Old 02-07-2014, 04:27 PM   #30
Got them from Tousley Ford for $325 shipped. I did an install write up at the below link. Sorry didn't know I couldn't use external links for photos.
Install of 2013-14 heated/pony projector mirrors - The Mustang Source - Ford Mustang Forums
Old 02-08-2014, 01:30 PM   #31
I got the mirrors from Tousley ford for $325 shipped. I posted a install write up on www.themustangsource.com because I used photobucket links for the pictures. If you have any question let me know.
Old 02-08-2014, 01:37 PM   #32
I got them from Tousley ford and it cost $325 shipped. I put a install write up on the mustang source because I didn't know I couldn't use photo links on hear.
04:37 AM
