Suspension problem - Mustang Evolution
Old 08-12-2013, 01:05 PM   #1
Whitelightning's Avatar
Suspension problem
Only at low speeds 05-35 when I turn I hear this whining/rubbing noise on my rear end. Only occurs when the wheel is 1/4 turned and anything past.
Power steering or pump or the lca?
Old 08-12-2013, 03:03 PM   #2
Region: New Mexico
Rear end only?
Does the sound change with speed?
Does it happen when turning in either direction?
Six7One is offline   Reply With Quote
Old 08-12-2013, 04:58 PM   #3
Originally Posted by Six7One View Post
Rear end only?
It happens at left or right. Only at the lower speeds but not above the 35 mph
Old 08-12-2013, 05:03 PM   #4
sebasflorez's Avatar
Originally Posted by Whitelightning View Post
It happens at left or right. Only at the lower speeds but not above the 35 mpg
How many miles on your car?
sebasflorez is offline   Reply With Quote
Old 08-12-2013, 05:12 PM   #5
77,000.
Old 08-12-2013, 05:15 PM   #6
Doe_Rae_mi's Avatar
Had the Same problem check ur gears, Sounds like a roaring noise. Person who fixed it said it was something with the gear or the spider gears
Old 08-12-2013, 05:26 PM   #7
Could it be fluid related? Cause I've been having problems with the breather valve?
I hope not since I've never touched the rear end as far as a gear swap?
---------- Post added at 06:24 PM ---------- Previous post was at 06:21 PM ----------
I'm worried cause I'm on vacation and I wanna make it through the week. Js
---------- Post added at 06:26 PM ---------- Previous post was at 06:24 PM ----------
To help better diagnose this freely, it really does it on the brakes and not so much on the throttle.
Old 08-12-2013, 05:46 PM   #8
Doe_Rae_mi's Avatar
Youve had a gear swap? What siize?
Old 08-12-2013, 06:04 PM   #9
No no no lol I have the stock 2.73!
Old 08-12-2013, 06:09 PM   #10
Doe_Rae_mi's Avatar
Ohhh hahah my bad, well I had the Same problem, is it a roaring sound?
Old 08-12-2013, 06:16 PM   #11
BlackedStang's Avatar
77,000.
Holy crap that's a ton of miles for a 2012.
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 08-12-2013, 06:28 PM   #12
Only when I turn below 35 mph and on the brakes. But going straight it's normal.
Old 08-12-2013, 06:51 PM   #13
Doe_Rae_mi's Avatar
Yea check your gears man, mine did the Same thing!
Old 08-12-2013, 07:08 PM   #14
Region: New Mexico
Maintenance is due man.
04:24 AM
