Will lowering the Mustang give me trouble over time? - Mustang Evolution
Old 08-13-2013, 11:23 AM   #1
MustangAtom's Avatar
Okay, I hate the gap on the mustang. I am thinking of lowering it soon. My concern is will I be getting lot of scrapes and is it bad for my suspension. Im driving a V6 2012
MustangAtom is offline   Reply With Quote
Old 08-13-2013, 12:27 PM   #2
Region: New Mexico
Depends on a lot of things.
How and where you drive.
How low you go.
Components you use. More than an 1.25" and your stock struts/shocks are out of optimal range so premature wear will likely occur and KILL the ride quick.
You'll want to get an alignment to be safe. Double check whether you need an adjustable panhard bar, camber bolts/plates, new upper control arm, lower control arms, swaybar bushings (links/mounts), bumpsteer parts.
How many miles do you have now and what is your budget? Are you JUST lowering or going for a performance related drop. You get some performance from the lowered CG of a drop. But that in and of itself is not a performance enhancement when other options exist.
Six7One is offline   Reply With Quote
Old 08-13-2013, 04:43 PM   #3
You will have to be more aware of conditions
some things to watch out for:
Speed bumps
The concrete parking lot stops.
Don't park on any grass ( Cats could catch grass on fire )
Driveway inclines.
There are probably more things but that is all I can equate to after having a lowered Corvette at one time.
Old 08-14-2013, 12:05 PM   #4
Tyriqq's Avatar
The topography of my city would kill my ride. I wonder why there is still a few that are determine to lower there cars here
Tyriqq is offline   Reply With Quote
Old 08-14-2013, 12:10 PM   #5
Midnight2012's Avatar
Get bigger wheels. Really the Mustang was designed for a gap. I prefer 17" tires in fact. Want a lowered look get 65 Chevy Impala and put some hydraulics on it. The Mustang is a Muscle Car.
---------- Post added at 11:10 AM ---------- Previous post was at 11:09 AM ----------
Speed bumps
Driveway inclines.
I have enough problems with those things stock.
And don't forget to have the pinion angle of your driveshaft adjusted.
Who wants to bet that's what caused those driveshaft failures?
Midnight2012 is offline   Reply With Quote
Old 08-14-2013, 02:59 PM   #6
tj@steeda's Avatar
If you do it the proper way ... then no. If you lower too much and don't upgrade the other parts of the suspension ... then you could get pre-mature wear.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 08-14-2013, 10:39 PM   #7
clamphier's Avatar
I love the look of mine and the ride quality really isn't that bad. The only thing is the top suspension mounts will pop eventually and will need new ones. But that's if you go as low as I did
clamphier is offline   Reply With Quote
Old 08-15-2013, 05:55 AM   #8
bucko's Avatar
I like driving my Mustang...I drive it daily, and about 300 to 400 miles a week. Lowering it for me would ruin the driving experience. I'd loose valuable suspension travel and the parking lot speed bumps would aggrevate me even more.
But I'm more into function than coolness.
01:38 PM
