Gear Question For Convertible Owners - Mustang Evolution
Old 08-15-2013, 07:31 PM   #1
Shockesh's Avatar
Waiting to hear back from accessories guy at my ford dealership for the max upgrade of gears I can go without voiding my warranty. He knows I can go to 3.31 but I want to go to 3.73. So my question is, what is everyone else running on there v6 convertibles? I keep reading coupe only on anything above 3.31. So I was just wandering what other vert drivers were running.
Shockesh is offline   Reply With Quote
Old 08-15-2013, 07:33 PM   #2
BlackedStang's Avatar
What's the difference between gears on a coupe and a vert? They are both going to be the same on both cars.
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 08-15-2013, 07:34 PM   #3
MidnightBlueGT's Avatar
Agreed ^
Old 08-15-2013, 07:41 PM   #4
Shockesh's Avatar
I thought the same thing but if you look at the 2014 brochure it clearly states coupe only for performance package.
Old 08-15-2013, 07:50 PM   #5
Oh your asking what the lowest gear ratio you can go without voiding warranty? If so, you're right, 3.31 is the lowest you can without voiding warranty.
Old 08-15-2013, 08:20 PM   #6
JimC's Avatar
As far as warranty - you realize that once you crack open the rear end and replace the gears that Ford won't warranty the rear end. The warranty is for the car that Ford built. They can't warranty the rear end that you have built afterwards, even if it is done at the dealership. That rear end is not the one they built and warranty.
As far as the rest of your warranty - unless the gears cause the failure it doesn't matter what gear ratio you go with. Even if you go with the 3.31, if that gear causes a failure then it is not going to be covered because it isn't what Ford built and guaranteed.
JimC is offline   Reply With Quote
Old 08-15-2013, 09:39 PM   #7
Intense.'s Avatar
It's my understanding if you get the dealer to do it and they provide the parts they'll give you a 12k mile/12 month warranty on parts and labor for the gear install.
'14 Race Red GT M6, premium, comfort package, Steeda stb
Intense. is offline   Reply With Quote
Old 08-16-2013, 01:16 AM   #8
Tyriqq's Avatar
I'm pretty sure a Vert is looked at more as a cruiser, so that's why it might not come stock with a PP. Other than that, there shouldn't be any reason why 3.73 can't be done on your Vert
Tyriqq is offline   Reply With Quote
05:25 AM
