Hid +drl - Mustang Evolution
Old 08-28-2013, 11:51 PM   #1
Whitelightning's Avatar
Hid +drl
Is there any way for me to have the projector lights such as raxioms and HID with my drl? I've heard that the drl just keeps the halo on, which I don't mind. I want switchbacks because let's be honest, they are cool.
Since ford won't disable them, time to learn about electrics and lighting and do it myself. (Safely)
Old 08-29-2013, 12:05 AM   #2
Black on Boss's Avatar
I'm thinking about getting a retrofit in mine with clear turn signals and switchbacks
---------- Post added at 02:05 AM ---------- Previous post was at 02:04 AM ----------
Old 08-29-2013, 06:45 PM   #3
What's the cost of a retro?
Old 08-29-2013, 06:48 PM   #4
I think that one was $650 for the set
Old 08-29-2013, 09:17 PM   #5
Now if I can only get them to work with DRL. I'll be a set man lol
Old 08-29-2013, 09:53 PM   #6
I'm sure they would for $650 lol
Old 02-25-2014, 02:47 PM   #7
Region: Iowa
did you ever figure out a way to install aftermarket headlights w the DRL or disable/bypass them?
theredguy70 is offline   Reply With Quote
Old 02-25-2014, 07:51 PM   #8
I have up on the idea as they will flicker.
Old 03-23-2014, 04:05 PM   #9
ArtU's Avatar
FOGs and DTR running at same time
Hi WL, remember we talked about FOGs and DTR lites before at the same time?
I traded my V6 with the converted GT fogs for a 2013 GT MT82 manual V8 Same color and Premium options last Monday. It seems looking in store windows that when I put my FOGS on, the DTR (the led white whiskers) go off. My V6 Auto did not do that. IN saying Fogs are put on I mean I put it in Parking Lite Mode and Pull the Fog switch out.
When I stop the car, put it in neutral, and no parking brake, fogs and DTR Whisker lights are both on. I think something is turning them off when in gear, did you ever find out?
I really need the Whiskers and Fogs to run at the same time, even in daylight, ; but perhaps I need to test at night, but so far I have not been able to.
Art [Looks like I got a new research project]
Old 03-23-2014, 04:42 PM   #10
Fender868's Avatar
Well. I have a 14 with stock hids and during the day it uses the led fogs for DRL. At night or with lights on it switches to hids ( I can optionally active fogs by pulling). Devising a similar thing would be really easy at any car shop worth it's salt. Lol
Fender868 is offline   Reply With Quote
Old 03-23-2014, 05:43 PM   #11
ArtU's Avatar
Humm, your outboard LED Whisker lites are not the normal DTRs? This is the trademark look of the 2013-2014s to go with the inboard HIDs.
Old 03-23-2014, 05:50 PM   #12
Fender868's Avatar
yes now that you mention they are on, but so are the fogs. I guess that's just applicable to models with the fogs
Old 03-23-2014, 06:07 PM   #13
ArtU's Avatar
So your GT fogs turn on as DRL as well as your whiskers with the Headlight Switch on 0[off] and/or Auto? I have not seen that yet but their is some differences in cars that could make it to Canada and those that are sent farther down.
My question is this, while driving slowing in a parking lot looking a shop window my Led Whiskers turn off if I put by headlight switch to P to pull out to turn on my FOGs. My GT switch like my V6 before it will not pull out for Fogs in the 0 [zero/off] position.
Old 03-23-2014, 08:04 PM   #14
Fender868's Avatar
So your GT fogs turn on as DRL as well as your whiskers with the Headlight Switch on 0[off] and/or Auto? I have not seen that yet but their is some differences in cars that could make it to Canada and those that are sent farther down. My question is this, while driving slowing in a parking lot looking a shop window my Led Whiskers turn off if I put by headlight switch to P to pull out to turn on my FOGs. My GT switch like my V6 before it will not pull out for Fogs in the 0 [zero/off] position.
Yeah it probably only works on auto. I haven't used anything else because... Auto lol, does the job for me. And yeah, you can't pull fogs on in the off position
05:46 AM
