BBK CAI - Mustang Evolution
Old 09-08-2013, 06:53 AM   #1
Jimmie's Avatar
BBK CAI
Put one on my 2010 V6 Mustang and couldn't get the Torque screws to tighten on MAS. Also after the test drive there no problems, but after it sat awhile wifey drove it to store and the check engine light came on. Took off the neg battery cable and cleared it again. Any ideas on what the problem could be....thank you in advance.
Jimmie is offline   Reply With Quote
Old 09-08-2013, 07:09 AM   #2
Just asking
Did you have the Battery disconnected when you installed the CAI????
If you did not disconnect the battery while installing the CAI there is no problem at all because it really needed to be disconnected and when you reconnected it the Computer would self adjust to the air flow change.
I'm thinking you did what needed to be done and should not have any more problems.
Old 09-08-2013, 08:25 AM   #3
Jimmie's Avatar
I did disconnect battery, but put the terminal back on for a min so I could get into trunk, then disconnected it again. I think that is where I screwed up. Anybody know it those screws on MAS have to be totally tight as I can not get them very tight. They are the ones that came with kit and directions said to use.
Old 09-08-2013, 08:34 AM   #4
I can't tell you about the screws
If you still have a problem with the check engine light you need to leave the battery disconnected for a minimum of 15 minutes.
I would think as long as the screws are holding the MAS and not letting it flop around it would be fine.
Old 09-08-2013, 08:39 AM   #5
Jimmie's Avatar
Thank you for the help Ronnie
06:15 AM
