Struts Going Bad - Mustang Evolution
Old 09-15-2013, 09:53 AM   #1
Tyriqq's Avatar
Struts Going Bad
I'm pretty sure it's my passenger side front assembly. I don't feel it giving more, but I am hearing it squeak over speed bumps. Since I live in the Chattanooga valley, the topography is crazy for a performance vehicle. Hell I live on a hill with a steep climb every day. My question is, what would be my best practical options?
Tyriqq is offline   Reply With Quote
Old 09-15-2013, 10:04 AM   #2
Region: New Mexico
Making sure that it's not the control arm bushings, sway bar ends or something simple would be a practical start. Bushings can get noisy.
Is your car lowered?
Six7One is offline   Reply With Quote
Old 09-15-2013, 10:10 AM   #3
Tyriqq's Avatar
Thanks, I didn't even think about those things. No to lowering. Not a wise move in this city
Old 09-15-2013, 10:17 AM   #4
FastFord13's Avatar
First off what year is it and is it stock?
Old 09-15-2013, 10:20 AM   #5
Tyriqq's Avatar
2012 and yes a stock setup
Old 09-15-2013, 10:24 AM   #6
FastFord13's Avatar
99.9% its your front lower control arms. I have a 13 and it did the exact same thing, squeaks and excessive noise coming from the front end over bumps. My car was 1 month old when I noticed it, I brought it into the dealer and they replaced them under warranty. It doesn't take them long to pin point if in fact it is your LCA. There is a tab for them I'll get it for you hang on. Tsb 11-10-17. Hope this helps.
Old 09-15-2013, 10:51 AM   #7
Tyriqq's Avatar
Sounds like a plan. Thank you sir
Old 09-15-2013, 11:00 AM   #8
FastFord13's Avatar
No problem, good luck and keep us posted.
Old 09-15-2013, 11:22 AM   #9
Whitelightning's Avatar
Does it do it when you turn the wheel sharp at low speeds. It sounds like the rear but it's only when I steer sharp and at low speeds you'll hear it groan
Old 09-15-2013, 11:28 AM   #10
FastFord13's Avatar
I noticed more at low speeds but it did it weather I was going straight or turning.
Old 09-15-2013, 12:37 PM   #11
Tyriqq's Avatar
Same here
Old 09-15-2013, 04:40 PM   #12
Gunner's Avatar
How long did it take your shop to fix?
Gunner is offline   Reply With Quote
Old 09-15-2013, 04:49 PM   #13
FastFord13's Avatar
They would have done it right away but the parts were back order and took a month to finally come in.
Old 09-15-2013, 05:48 PM   #14
Gunner's Avatar
Mine is doing the same so I'm going to have them look at it when it goes in for an oil change next week
Old 09-15-2013, 06:00 PM   #15
FastFord13's Avatar
I would call them before your appointment to tell them about it so they make the time to road test it. Where I bought the car I went back to them after I noticed the problem but like you I thought it was struts or something. They took it for a road test, put it up on the lift etc and came back to me and said the car is fine. I said it wasn't fine that that noise is not normal and they said they all do that! Yeah OK I told them and went to another dealer where it took them all about 5 minutes to say its your LCA and we ordered them for you! They were surprised the other dealer didn't catch it right away. Needless to say I switched dealers!
Old 09-15-2013, 06:03 PM   #16
Oakville's Avatar
I have the same problem with my 3 month old 2013 V6. Parts are back ordered but they expect them in within a couple of days.
Oakville is offline   Reply With Quote
Old 09-15-2013, 06:03 PM   #17
Gunner's Avatar
Yeah I just emailed the service manager about it and attached the tsb. I will call them tomorrow to discuss further
Old 09-15-2013, 06:13 PM   #18
FastFord13's Avatar
Good idea.
Old 09-16-2013, 05:38 AM   #19
bucko's Avatar
If it were a strut, you'd see oil on the shock cartridge; a tell tale sign they are bad.
Old 09-16-2013, 06:56 PM   #20
So is it front or rear in your opinion, on the new gens I'm lost. I'm a classics guy.
Either way I'm replacing whatever it is with better aftermarket
Old 09-17-2013, 01:34 PM   #21
Oakville's Avatar
The parts are in and are covered by warranty. Yay!
Old 09-17-2013, 01:40 PM   #22
FastFord13's Avatar
Well in my case there was no mistaking it was in the front end. I could also feel it in the pedals also,(clutch,gas and brake) it literally felt and sounded like the car was falling apart!
Old 09-17-2013, 06:22 PM   #23
It has this rubbing feeling when on the brakes and turning. But it'll groan at near full turning radius going slow. Front upper or lower control arm? Or is it only the upper that's in the front
Old 09-17-2013, 06:35 PM   #24
FastFord13's Avatar
Front lower control arms. Its the two bushing on the horse shoe that you see in this picture. I believe there are called hydra bushings but I could be wrong. Lol http://578e7a9bafc08e847f59-b21544d4...com/m3075d.jpg
Old 09-17-2013, 07:15 PM   #25
I'll go aftermarket and me and padre will spend a weekend doing it. Gotta drop the springs I assume?
07:20 PM
