Rear strut bar - Mustang Evolution
Old 09-20-2013, 09:12 PM   #1
Whitelightning's Avatar
Rear strut bar
I bought the rear strut bar from CJP for $99. It's the solid Shelby one. And I'm wondering how do I install it. I took a socket and ratchet to the nut and turned it about 30 times. Nothing gave really. How do I install it?????????
Old 09-21-2013, 08:34 AM   #2
Region: New Mexico
Use an impact wrench, you may be turning the shock shaft. You can also hold the smaller hex at the top of the shaft while you rotate main retaining bolt with an open wrench. Once you break that free, you'll stop turning the shock shaft while removing the nut.
Six7One is offline   Reply With Quote
Old 09-21-2013, 10:19 AM   #3
i only have one nut and what looks like a washer.
Old 09-21-2013, 12:04 PM   #4
sprdave's Avatar
I have one installed on my car.You need to use a wrench or adjustable
wrench and hold it at the top of the shock and then loosen the shock
nut.If you don't do this the shock will just keep turning around.
All I used was an adjustable wrench on the top part of the shock
and a wrench on the shock bolt.Easy install,only took five minutes.
Removing the floor liner also helps in seeing what your doing.
sprdave is offline   Reply With Quote
Old 09-21-2013, 03:42 PM   #5
Originally Posted by sprdave View Post
I have one installed on my car.You need to use a wrench or adjustable wrench and hold it at the top of the shock and then loosen the shock nut.If you don't do this the shock will just keep turning around. All I used was an adjustable wrench on the top part of the shock and a wrench on the shock bolt.Easy install,only took five minutes. Removing the floor liner also helps in seeing what your doing.
Excuse my stupidity on something so simple. Where do I use the wrench?
Old 09-21-2013, 06:51 PM   #6
Region: New Mexico
You aren't stupid. Do you see the top of the shaft that looks like a bolt? It is what looks blue in the image.
That's what you hold with a crescent wrench while rotating the larger nut you were turning earlier.
Old 09-21-2013, 06:54 PM   #7
sam62893's Avatar
Rear strut tower brace for dummies
ID:	129800   Click image for larger version
Old 09-21-2013, 07:28 PM   #8
You aren't stupid. Do you see the top of the shaft that looks like a bolt? It is what looks blue in the image. That's what you hold with a crescent wrench while rotating the larger nut you were turning earlier.
Now it makes a lot of sense. I never noticed the notch. I thought it just kinda feathered out. Off to get a crescent and wrench set!
Old 09-21-2013, 07:39 PM   #9
Region: New Mexico
Save up for an electric impact of you don't own one or a compressor.
Old 09-21-2013, 09:22 PM   #10
sam62893's Avatar
Electric impacts are the shizzzzz!!
Old 09-21-2013, 09:28 PM   #11
silvrbullet2012's Avatar
Love electric impacts!!! It's way better than air. Well the. Again I had a small tank. But still! Never met a bolt it couldn't take off!
silvrbullet2012 is offline   Reply With Quote
Old 09-22-2013, 09:34 PM   #12
ak_stang's Avatar
Region: Alaska
Is that a Nintendo 64?!!!
ak_stang is offline   Reply With Quote
Old 09-22-2013, 09:52 PM   #13
sam62893's Avatar
Hahah yes sirrrr I was redoing my rear seat delete so I put it in my trunk
Old 09-23-2013, 01:46 PM   #14
Charlie_santos's Avatar
Omfg your a genius!!!!!!
Old 09-23-2013, 05:58 PM   #15
pwrby4d's Avatar
U only have one nut? Lol. Jk.
pwrby4d is offline   Reply With Quote
08:13 AM
