Problem with starting - Mustang Evolution
Old 09-25-2013, 07:51 PM   #1
Pickeringeric's Avatar
Car ran fine to work come out to move it on tge pathmemt get a click click sound lights flashing on the dash bought it used 29,000 miles 2013 prem converitble was a rental before dodge dealer bought it auction got it runing with start let it run 10 min shut off back tp work come out for lunch still same problem!? anyone out there any ideas?
Pickeringeric is offline   Reply With Quote
Old 09-25-2013, 07:59 PM   #2
fordfan100's Avatar
Battery might be going dead.
fordfan100 is offline   Reply With Quote
Old 09-25-2013, 09:26 PM   #3
Tyriqq's Avatar
Yup, dead cell in your battery. Stop by an autozone and let them test it for you for free
Tyriqq is offline   Reply With Quote
Old 09-25-2013, 10:01 PM   #4
Jayjay's Avatar
You say you got a 2013 model, take it to the dealer they should be able to replace the battery for a new one. It's only 1 yr old should not be bad
Jayjay is offline   Reply With Quote
Old 09-26-2013, 12:29 AM   #5
Thanks ill call them
Old 09-26-2013, 04:24 AM   #6
somedopebeats's Avatar
You from pickering, ontario?
somedopebeats is offline   Reply With Quote
Old 09-26-2013, 06:32 AM   #7
Strange Mud's Avatar
I would check battery connections B4 bringing it to dealer. I wonder if it is an alarm or anti-theft issue though. It should be under wtty unless it's an aftermarket system though. Good luck.
edit: after figuring you meant jump start more likely it is the battery but check connections anyway.....
Old 09-26-2013, 07:05 AM   #8
Nope rochester ny
---------- Post added at 08:05 AM ---------- Previous post was at 08:03 AM ----------
Okay ill try that too thanks for the help! I just bought it last saturday so Idk why theres problems now >.<
10:51 PM
