Strut bar install - Mustang Evolution
Old 10-04-2013, 12:02 AM   #1
Whitelightning's Avatar
Strut bar install
Or my rear strut bar in from CJ pony parts. Dipped it black and was ready for install. Till I stripped the nut out and now it's stuck. Hopefully a shop across from work can fix it (2 miles away) and maybe go ahead and install the bar. Here is why you should pay someone to do the rear.
ID:	131361   Click image for larger version
ID:	131363   Click image for larger version
Old 10-04-2013, 12:47 AM   #2
Venomouz831's Avatar
Get it with some vice grips
)02 Gt, Founder of WE2G
Old 10-04-2013, 01:16 AM   #3
Tyoung68's Avatar
Thats your shock how did you strip it?
Old 10-04-2013, 06:29 AM   #4
Well that's kinda it. I did use vise gripes and it stripped it out at the top.
Old 10-04-2013, 06:41 AM   #5
CVH
CVH's Avatar
You are turning the right nut? Use the vice grip to strong clamp the top of the strut, then back out the bolt. If it wont back out, spray it very lightly in the threads with some WD(dont make a mess or you wont be able to grip it). Then try to thread in and then out.
My nut was loose enough to unthread with my hand when I got it that close to the top.
Good luck
CVH is offline   Reply With Quote
Old 10-04-2013, 06:48 AM   #6
It's not me, it's you.
primer2tone's Avatar
Yeah, it looks like you might have put the vise grips too close to the threads and distorted them enough to jam the nut on its way out.
A shop can put an air ratchet on it and pop it off real quick. Just get yourself a small file so you can clean up the threads before you put the nut back on. And if the threads are too boggered up, you may have to replace that shock.
Old 10-04-2013, 08:08 AM   #7
Originally Posted by primer2tone View Post
Yeah, it looks like you might have put the vise grips too close to the threads and distorted them enough to jam the nut on its way out. A shop can put an air ratchet on it and pop it off real quick. Just get yourself a small file so you can clean up the threads before you put the nut back on. And if the threads are too boggered up, you may have to replace that shock.
Yeah the mechanic said he could do it and also install the brace. Hopefully it goes well. Up side is I get to look at my car all day as it's across the street from me.
Old 10-04-2013, 08:14 AM   #8
Cool.
Old 10-04-2013, 04:56 PM   #9
Used a special socket to install. I recommend one. You feel the tightness even in your back going in a straight line.
Dipped it black.
Old 10-04-2013, 05:02 PM   #10
Gunner's Avatar
Don't close the trunk with your keys in there
Gunner is offline   Reply With Quote
Old 10-04-2013, 08:47 PM   #11
Lmao!
Old 10-04-2013, 10:19 PM   #12
Loc: Austin,TX
Excellent advice!
Old 10-04-2013, 10:41 PM   #13
Gunner's Avatar
Anytime always here to help.
Old 10-07-2013, 05:08 AM   #14
bucko's Avatar
Or you can pull down one of the back seats to get that key...provided you did not lock the doors prior to tosing the key back there...
Old 10-07-2013, 06:32 AM   #15
Always wondered how one could get keys since we don't have a trunk hole. Leave it in the ignition, will never lock.
Old 10-10-2013, 09:30 PM   #16
I need some help here. I hear a squeak from the rear and i know the problem. Yet I don't know what to do. One nut is tighter down insanely, the other is just kinda there but looks better. So am I too tight, too loose, or correct? The compacted rubber is the passenger side, the driver side is the regular.
ID:	132122   Click image for larger version
Old 10-10-2013, 10:22 PM   #17
sprdave's Avatar
You probably have the one nut to tight.When I installed my bolts
I only tightened them so they were snug.You don't want to compress or squish
the rubber.
I have no noise or sound at all.
sprdave is offline   Reply With Quote
Old 10-10-2013, 10:51 PM   #18
Originally Posted by sprdave View Post
You probably have the one nut to tight.When I installed my bolts I only tightened them so they were snug.You don't want to compress or squish the rubber. I have no noise or sound at all.
I messed up the one that looks squished. I was going to get the one to semi compress just barely and the other slack off. But I didn't know which was right. I had the shop install it because I messed up getting one of them off and needed air tools. Was gonna take it back but thought I would just adjust it myself.
Old 10-11-2013, 03:52 AM   #19
bucko's Avatar
You should tighten down these nuts (or any fastner related to shocks/bussings) to the point that the rubber "just begins" to squish. Don't go past that.
Old 10-11-2013, 07:59 AM   #20
That's the answer imma lookin for!
10:07 PM
