Rear axle removal? - Mustang Evolution
Old 10-04-2013, 12:18 AM   #1
crazychink's Avatar
Rear axle removal?
Long story short I need to remove the rear axle to change the rear caliper bracket. And to take the axle out I need to open the differential cover to take the c clamp out. I've never done differential work before so I am wondering how difficult is it? And if it's really necessary to go to the professionals? ( I already have all the brake fluid, gears oil and friction modifier)
I recently changed the wheels and front brakes. Now I have to do something about the puny rotors and calipers in the back!
crazychink is offline   Reply With Quote
Old 10-04-2013, 09:12 PM   #2
ak_stang's Avatar
Region: Alaska
To change the brakes and calipers all you have to do is remove the wheels, not the entire axle, if I understand your question right. But iihs.net/fsm has the ford service manual in pdf form it should be under 2011/workshop manual/driveline or araound there, website has helped me out many times
Update
Here is a direct link to the entire axle assembly workshop manual
http://iihs.net/fsm/?dir=752
ak_stang is offline   Reply With Quote
Old 10-04-2013, 10:11 PM   #3
layton's Avatar
Originally Posted by crazychink View Post
Long story short I need to remove the rear axle to change the rear caliper bracket. And to take the axle out I need to open the differential cover to take the c clamp out. I've never done differential work before so I am wondering how difficult is it? And if it's really necessary to go to the professionals? ( I already have all the brake fluid, gears oil and friction modifier) I recently changed the wheels and front brakes. Now I have to do something about the puny rotors and calipers in the back!
How much is your car lowered? And what springs/kit do you have?
borla atak axle-back exhaust, 19in rtr wheels wrapped in 255/40r19 goodyear fl supercar tires, airaid cai, tinted windows 10%, grabber blue custom stripes. and last a bad a** driver
layton is offline   Reply With Quote
Old 10-05-2013, 12:45 AM   #4
crazychink's Avatar
Update
Ford Service Manuals - SECTION 205-02 [Rear Drive Axle Differential-Ford 8.8 Inch Ring Gear]
Thanks for the link to the workshop manual. I have a different rear caliper bracket that needed to be put on and unfortunately the caliper bracket is bolted on behind the axle. So looks like I have to take it out. I do have the manual on how to do it but just wondering if this is something I should mess with myself or get it done professionally.
I have the Steeda Pro-Action Shocks & Structs and the SR Performance Lowering Springs. The springs are advertised as 1.5" drop
Old 10-05-2013, 03:58 PM   #5
ak_stang's Avatar
Region: Alaska
Its not hard at all, I replaced my axle with jackstands, all you have to do is remove the diffcover and then remove the pinion shaft, pull the c clips and the axle slides out
05:37 AM
