Gear ratios - Mustang Evolution
Old 10-07-2013, 08:37 PM   #1
Gear ratios
Does anyone know what the gear ratios are on the automatic. It feels that the 2 top gears are both OD hence the very low rpm at cruise sp. The eng seems to be lugging. Acceleration requires a pause, select & shift to lower gear - all this is annoying. My Ford Escape (6cyl/auto- only 6sp is OD) shifts much better than the Mustang and seems faster on acceleration.
I know a tune will change the shift pattern & hopefully maintain a better rpm relative to sp, but I guess gas mileage will suffer. I guess a tune would be similar to driving in "sport mode" - keeping out the 6th sp. Am I correct?
Deep Impact is offline   Reply With Quote
Old 10-07-2013, 08:50 PM   #2
Siber Express's Avatar
If it is a Stock gear without the optional 3.31's it is a 2.73.
Depending on what year Escape, it could have 3.92, newer ones have 3.51.
BTW my wife's Rav4 seems faster than mine but run them together and I pull away.
Old 10-07-2013, 08:52 PM   #3
The 2 top gears are OD gears,i don't know the ratios off the top of my head though. A tune wont keep you out of a gear, but it will adjust spark, timing, compression ect.. If you get a mild tune you can see an increase in performance and mpg, a more aggressive tune you may lose a few mpgs though
---------- Post added at 06:52 PM ---------- Previous post was at 06:51 PM ----------
I think he means actual gearing ratios (transmission ratios, not rear end)
Old 10-07-2013, 10:23 PM   #4
alrefire's Avatar
The 2 top gears are OD gears,i don't know the ratios off the top of my head though. A tune wont keep you out of a gear, but it will adjust spark, timing, compression ect.. If you get a mild tune you can see an increase in performance and mpg, a more aggressive tune you may lose a few mpgs though ---------- Post added at 06:52 PM ---------- Previous post was at 06:51 PM ---------- I think he means actual gearing ratios (transmission ratios, not rear end)
I don't remember where, but there's a chart somewhere online... (I know, helps a lot)
Let me see if I can find it
---------- Post added at 10:23 PM ---------- Previous post was at 10:19 PM ----------
Found it!!
http://www.cartobuy.com/wp-content/u...tang_Specs.pdf
Old 10-07-2013, 10:28 PM   #5
Ish416's Avatar
Not sure if there is any difference between the 3.7 and 5.0 ratios. Here they are for the 5.0 and the only ones I could find for the Ford 6R80 transmission.
Automatic
1 - 4.17
2 - 2.34
3 - 1.52
4 - 1.14
5 - .86
6 - .69
Old 10-08-2013, 06:04 AM   #6
bucko's Avatar
A tune that can adjust the compression????
Old 10-08-2013, 07:10 AM   #7
Thanks
Got the info re gear ratios. 2 OD's that explains the lack of giddy-up from slow speeds. Am I correct in assuming that a tune will greatly delay the OD's until at only highway speeds? If so how can that help gas mileage?
Thanks..............
12:33 PM
