4.10 set - Mustang Evolution
Old 10-20-2013, 03:24 PM   #1
AmericanBulldog's Avatar
4.10 set
Was about to finally order the gears and then i saw some options for "gear install kit"
"Add 8.8in Rear Gear Pinion Bearing" and "Add Traction-LOK Rebuild Kit w/ Carbon Discs"
do i need any of those also? I was going to find a shop to install them after getting them but i need to know if i needed "extra" stuff.
thanks,
AmericanBulldog is offline   Reply With Quote
Old 10-20-2013, 03:30 PM   #2
You will need the installation kit, and probably the pinion bearing. The rebuild kit is not necessary because your car is relatively new.
If you find a shop to install them they should know everything that you need so you probably don't even need to order them.
Most shops when they give you a quote will give you a price for each thing individually, so gears, install kit, rebuild kit (if needed). So you can check the prices from them and see if you can get any of the stuff cheaper online, but if they are cheaper then you can just have them provide everything.
06:37 AM
